Old 01-28-2014, 10:23 PM   #1
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
What's the little red light, rear of 65 TW?
For those of you in the know can you tell me what this little red light might be for. It is located in the rear equipment area on the street side upper left corner.
ID:	204558   Click image for larger version
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 01-29-2014, 02:25 AM   #2
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
This is the "polarity" light. It is a safety device of the era, but incompatible with modern GFCI safety devices. It was used to tell you if the receptacle you were plugged into had the load & the neutral reversed. This can be quite common in campgrounds that were wired by non electricians or a handyman who didn't understand. The theory was that if the load & neutral were wired backwards in the receptacle & the ground was somehow connected to the neutral in the trailer, the skin of the trailer would become live, causing an unsafe condition. The light would go on, alerting you to the fact that a problem was present. The way it works is that one side of the filament is connected to the ground & the other side to neutral. If the receptacle was wired correctly, the light would stay off, if not, the light would go on. Modern GFCI receptacles operate differently, & will "pop" if a vintage trailer equipped with a polarity light is plugged into one. This does not necessarily mean that your trailer is wired incorrectly, it just means that you need to remove the polarity light & try again. The GFCI operates around the principal of differentials between the three posts, i.e. ground, load & neutral. As soon as it sees a condition that doesn't suit its parameters, it'll pop.
Hopefully this helps out.
Colin
Colin H is offline   Reply With Quote
Old 01-29-2014, 07:20 AM   #3
1961 28' Ambassador
Mesa , Arizona
Thank you Colin for your answer explained it well. We will install new and modern GFCI but leave the little light in its place for an eventual next owner down the road and they can find the answer on the forum.
Hittenstiehl
Old 01-29-2014, 07:52 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It will be necessary to disconnect the polarity light. It will cause problems with the GFCI.
Old 01-29-2014, 07:58 AM   #5
1961 28' Ambassador
Mesa , Arizona
Thanks twinkie we will just leave it there for looks and confusion.
Hittenstiehl
first ceiling light Segue Lights - Interior & Exterior 2 05-14-2011 01:18 PM
Propane light doesn't go off dekew Refrigerators 7 05-07-2011 02:10 PM
Please advise..Red light? ohwally Water Heaters, Filters & Pumps 2 05-04-2011 04:56 PM
Rear light housing seal--how? OB Bambi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2011 04:33 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
