Old 10-22-2011, 07:00 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
What Type Soldering Iron
I'm ready to replace old bulb marker lights with new LED lights. I've read that several of you recommend soldering and heat shrink tubing. This will require balancing on a ladder and keeping the solder on the wire. What type of soldering iron/gun should I be looking for? Thanks!
Roadrunner is offline   Reply With Quote
Old 10-22-2011, 07:56 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Flexible...
When I did our 63 Safari I line twisted,(strip 1/2" off each wire, overlap the bare wires end to end and twist them around each other), and covered with shrink tubing. Never had a problem in 18 Seasons.
Don't think soldering is appropriate for a connection that may be better if kept flexible.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-22-2011, 08:03 PM   #3
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
Radio Shack has a cheap 15W/30Watt selectable iron that is cheap and works just fine, you don't need anything more then 30Watts for soldering wires.
Damon
damonbeals is offline   Reply With Quote
What type of screws (and what size) can I use in walls Maggiefoss Upholstery, Blinds, Walls & Interior Finishes 3 09-02-2011 05:28 AM
Interior aluminum type on 71' Darkspeed General Interior Topics 19 08-22-2011 05:29 PM
Pie Iron cooking sempi2 Stella's Kitchen 12 07-22-2011 11:50 AM
Can type 3 glass bars go on a '66? deploy Windows & Screens 6 07-08-2011 01:45 PM
Exterior Aluminum type for an 1988 Excella? Rob&Julie Ribs, Skins & Rivets 0 02-14-2011 08:04 AM
