Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-14-2008, 12:06 PM   #1
beckybillrae
beckybillrae's Avatar
Profile:  1986 31' Sovereign
Schererville , Indiana
what to do w/extra wire?
I have new running lights for my trailer. I realize they are grounded by the screws that hold them to the trailer & the ground wire coming out of the trailer doesn't have a home! What do I do with the extra wire? Sorry, I'm not much at electrical, so excuse me if this is a dumb question! Thanks in advance....
Becky
beckybillrae is offline   Reply With Quote
Old 06-14-2008, 12:17 PM   #2
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Becky,
I drilled a hole through the base of the clearance light, ran the ground wire through it, crimped a ring terminal on it and then ran the mounting screw through it to secure the mount base. The last set of three red LED clearance lights I bought for the top rear area were 2 wire units which just plugged into the existing wires of the trailer.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-14-2008, 12:19 PM   #3
beckybillrae
Sounds like a plan.....Thanks!
Becky
Old 06-14-2008, 04:42 PM   #4
DEITZ645
DEITZ645's Avatar
Profile:  2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 84
Extra Wire
Becky,
I used shrink wrap tubing to cover the unsed grounding wire and just tucked the unused grounding wire behnd the new light.
Also see this thread...
http://www.airforums.com/forums/f447...lla-39116.html
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package
1987 34' Excella 1000
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
AIR #14487
WBCCI #7429
DEITZ645 is offline   Reply With Quote
Old 06-14-2008, 05:15 PM   #5
beckybillrae
Sounds like an even easier plan! Off to the hardware store I shall go for new stainless screws & shrink wrap. Thanks again! And thanks for the link too--your is just like mine & pictures speak volumes!
Becky
Old 06-14-2008, 10:30 PM   #6
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
I just replaced all the markerlites on my 77 Overlander .The wire that is with the lite I just rolled up inside the base of the lite. My marker lites are Grote and only 1 wife the screws ground the lite. I caulked the screwholes and the wire gromets before installing the new lites. The 31yr old lites had fiber gaskets,the new do NOT,but they do have ample drainage. I got my lites a the local Semi trailer place. Fruehauf Dealer they are the same lites. My Lites were $1.95 each. RV places get from $4.25 to $7.25 each for the same thing
Mikethefixit is offline   Reply With Quote
Old 06-15-2008, 07:06 AM   #7
DEITZ645
DEITZ645's Avatar
1987 34' Excella
Images: 84
Becky,
As you know the wires coming out of the trailer are very short. So I did not want to cut wires to put new connectors on. I bought "female" bullet connectors to connect the new lights to the hot lead coming from the trailer. I also put shrink wrap over the entire hot lead connection to prevent them from coming apart or getting a metal against metal short. All in all the new bullet connectors and shrink wrap made for a very nat job. I also used all new mounting screws to ensure the ground to the trailer body was good.
Good luck an let us know how you make out.
PS. I searched for MONTHS to get the exact same replacement lights, but it seems nobody makes them anymore. The only reason I went the way I did was becuase the camping season was coming up and I needed the trailer ready for PA state inspection and camping.
AIR #14487
WBCCI #7429
Two wire and three wire converters??? max7 Batteries, Univolts, Converters & Inverters 1 02-28-2008 06:27 PM
Extra, Extra!! codybear Airstream "In the News" 3 04-16-2007 04:59 PM
Extra converter wire? Phil Gobie Electrical - Systems, Generators, Batteries & Solar 0 12-20-2006 05:56 AM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 08:52 AM
