Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 09-03-2009, 04:15 PM   #1
ryan3326's Avatar
Profile:  1976 31' Sovereign
Columbus , Indiana
What is this?
We have recently purchased our first AS - a 76 Sovereign. Located directly over the door there is a protruding (something?) I am not sure if it is a light or a vent or what. It is shrouded in aluminum and has a white plastic insert in it. It is in a logical place for a light, but it doesn't turn on - so if it is a light I would need to replace the bulb (one of dozens) and I am unsure of how to access the old bulb to replace.
Can anyone "enlighten" me on what this is?
ryan3326 is offline   Reply With Quote
Old 09-03-2009, 04:24 PM   #2
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
It's a light! There's a bulb up inside behind that palstic lens. Bulb might be burned out, or the socket all corroded (hopefully only a bad bulb).
Chris
Old 09-03-2009, 05:10 PM   #3
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
And the light switch should be immediately next to the door, inside.
Welcome to the forum!
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
EX-WBCCI # 8371
AIR # 8239
StingrayL82 is offline   Reply With Quote
Old 09-03-2009, 05:21 PM   #4
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 57
Send a message via Yahoo to Alwhisman
If yours is the same as mine, there are screws on the top to remove the housing and access the bulb and socket.
I didn't have to worry about it on mine since the leans was gone, but discovered the screws later. I replaced mine with an LED (red).
Alwhisman is offline   Reply With Quote
Old 09-03-2009, 05:55 PM   #5
ryan3326's Avatar
Columbus , Indiana
Looks like they have sealed the unit housing down - that is why i hesitated to remove the screws. If I take it off - what sealant is recommended to replace it. It is a grey colored paste it looks like.
Old 09-03-2009, 05:59 PM   #6
San Angelo , Texas
Images: 37
I find Parr bond works well, but if you check out Airstream's website, they have a recommendation of which sealant to use where, in their customer service portion of the site.
SFC Frederic Lynes
EX-WBCCI # 8371
AIR # 8239
Old 09-03-2009, 09:46 PM   #7
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
If you remove the two screws at the bottom only - look up from the step - you can lift the leading edge up enough (just a little) to remove the lens. If the sealant is vulkem and in decent shape it may flex enough without breaking the seal. When you lift up slip a thin blade in between the lens and housing to get it started - it doesn't take much to get it out.
You might think about replacing the screws with stainless while your at it.
OHIO - WE ARE THE MOTHER SHIP
Gary
Ganglin is online now   Reply With Quote
