Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-08-2008, 11:01 AM   #1
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
What did you do for ceiling lights?
I replaced the old ceiling fans in my 1973 31' International with 3 new Fantastic ceiling fans. This of course also means that the older lighting that was built in around the ceiling fans is now obsolete. So I am contemplating my options for what to replace that ceiling lighting with. One idea is to put a row of recessed puck lights down the middle. I have been looking at the following product:
12 Volt Recessed Ceiling Lights - Boat - Marine Lighting - SailorSams.com - Nova ICM-8777 Optional Switch
One thing I like about this type of light is that it is available with a built in switch. The idea would be to connect the string of maybe 9 lights to the switch by the entry door. When leaving the trailer any of the ceiling lights that are on could be turned off with one switch. When inside it would be easy to turn on the ones that are needed and turn off others. For example going to bed you could turn off units as you headed back to the rear bedroom.
I am open to other options. I have even wondered about whether or not I could build something around the three fans that would be an update to the original lighting.
So what did you do?
Malcolm
malconium is offline   Reply With Quote
Old 07-08-2008, 11:10 AM   #2
Mexray
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
Check out this thread...many of us are using LEDs when possible...use less current, etc.
LED lighting retrofit for interior lights
I posted an explanation of my LED ceiling lights, and then posted some pic's below...take a look.
Ray
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated
Old 07-08-2008, 11:36 AM   #3
SmokelessJoe
SmokelessJoe's Avatar
Profile:  1976 Argosy 24
TORONTO and Southwestern , Ontario
Malcolm:
How we installed 8 puck-style down lights through out the trailer is described in post #42 here:
Contemporizing 1976 Argosy D - opinions please
I used the Frilight dimmer obtained from Sailor Sam.
One at the front door controls four recessed down lamps in the front of the cabin; another on the amidships bulkhead wall controls the rear set of four.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 07-08-2008, 07:01 PM   #4
malconium
Portland , Oregon
Ray
Hi Ray,
For some reason the Dr LED website shows the spot light that you used but does not list it for sale in their online store. Am I missing something? Where did you buy yours?
Malcolm
Old 07-08-2008, 07:05 PM   #5
malconium
Portland , Oregon
Originally Posted by SmokelessJoe View Post
Malcolm:
Sergei
Hi Sergei,
You have a nice looking installation. I gather you decided to use Xenon bulbs. How is the light level for you? If I was reading correctly your units put out something like 18watts each and with 4 in the living room that would be 72 watts on max illumination. I would guess that would be pretty bright.
Malcolm
Old 07-08-2008, 07:43 PM   #6
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
The fluorescent round tube units that come in a round or square fixture are cheap and efficient and throw a lot of light. Available from the usual suspects.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-08-2008, 08:00 PM   #7
Mexray
Mexray's Avatar
Malconium...
I bought my Spot Saturn Ring type LED units from West Marine Products, a large marine supply company with retail outlets in many cities, and online.
I went to the Dr LED site, and found as you did that the Saturn Ring isn't in their Online Store...curious...I sent them an email asking what was up...and will pass along when they reply.
They are a nice, compact unit, and I hope they didn't discontinue them...
Ray
Mark Twain, updated
Old 07-08-2008, 08:18 PM   #8
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
I went simple in our Sovereign, I put a 120v flourescent fixture in the bezel over the left and right window curtain brackets in the living room, a 12v flourescent thinlite fixture in the kitchen, a similar fixture in the bedroom centered on the ceiling, and converted the incandescent fixtures over the beds into flourescents, using thinlite single tube fixtures. I'm in the process of getting two more single tube fixtures for the bathroom vanity.
Change is inevitable, except from a vending machine
AIR#2611
Old 07-08-2008, 11:00 PM   #9
Mexray
Mexray's Avatar
I received a rapid reply from the folks at Dr LED tonight...
They will begin selling a new, improved version of the Saturn Ring LED unit, called the MKII in September.
Here's a pre-release pic of the MKII:
Name:	Dr LED Saturn  Ring MKII.JPG
Mark Twain, updated
Old 07-09-2008, 11:12 AM   #10
malconium
Portland , Oregon
Can you be more specific as to which fixtures you used and where you got them? There are so many products out there it is sometimes hard to dig through all the information. I know when I went to the thinlite website it was not particularly easy to find anything.
Malcolm
Old 07-09-2008, 12:03 PM   #11
overlander63
Images: 58
Malcolm
I'll give you part numbers this evening when I get home. The 120v lights were just "el cheapo" single-tube lights I got from Home Depot for $12 each.
AIR#2611
Old 07-09-2008, 12:35 PM   #12
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
Thin-lite makes a variety of 12v fluorescent fixtures.
thinlite Products Page
You can e-mail them for a local seller.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 07-09-2008, 12:39 PM   #13
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Royce documented the LED lights he built for his Argosy here:Minuet LED light design. He really did a great job!
Vaughan
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Ceiling lights niftypkg Lights - Interior & Exterior 4 03-04-2007 05:01 PM
Round ceiling lights TroutStream General Interior Topics 23 05-09-2006 10:25 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
how to remove ceiling lights NewStreamer General Interior Topics 18 02-01-2003 04:41 PM
