Old 08-27-2008, 06:26 PM   #1
1969 27' Overlander
austin , Texas
weird noises and lights dimming
Hello everyone,
Got a question.I replaced my converter and battery and all is going well with that,good charge etc.The problem is my lights dim then go back to bright and at the same time I hear a strange noise like a tree branch dragging on the outer skin.I dont have any tree's around me!It sounds like the noise is above the sink but I cant pinpoint it.I tightened all connections in the elec. boxes,all my fuses are good.I am plugged into the shore and the battery is connected correctly.Any help would be fantastic!Thank you all in advance!
Slapshift and his 69"challenges and oppurtunities"Overlander
slapshift is offline   Reply With Quote
Old 08-27-2008, 06:36 PM   #2
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
Check the exhaust fan above the stove it may be bad.
Ramp is offline   Reply With Quote
Old 08-27-2008, 08:37 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
It might be your water pump?? mine will do that once in a while when it is trying to pump up the system, it will cycle slow. I have no idea unless you got mice running around shewing wires between the skin and the interior?????
mustang is offline   Reply With Quote
Old 08-27-2008, 08:38 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
hey welcome by the way slapshift sounds like your a dragracer
Old 08-28-2008, 05:29 AM   #5
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by slapshift View Post
Hello everyone,
Hi slapshift; It seems to me as you have a short or bad ground. Best way to determine it, is to disconnect your converter temporarily. Shut down all switches. Disconnect the positive lead from the battery. Hook up amp meter between the positive lead and the battery post. Turning on one switch at the time, look for the indication of the draw on the Amp meter. Be aware that amp meter is polarity sensitive, it can read in both directions. If your test meter starts at 0 from left to right instead of being in the center of the scale you may have to switch meter leads to get a reading. If you hear that much noise it must be pretty good short or loose ground wire in that area, which is indicated by dimming lights. If this is the case you have a lot of nasty work ahead of you. However until you can address the issue you can leave the affected circuit disconnected if you can do without it. Good luck. "Boatdoc"
boatdoc is offline   Reply With Quote
Old 09-01-2008, 04:59 AM   #6
1969 27' Overlander
austin , Texas
Thanks everyone for your help! I found the problem this weekend and got it squared away.Seems someone moved the thermostat on the furnace by accident to 90.Well with no bottles to kick it off it kept trying to do it's job.Turned off the heater and all is well.
Strange noises from the stereo? hshovic Audio, Video & TV 60 07-12-2009 08:45 PM
Voila! Strange noises from stereo fixed! hshovic Audio, Video & TV 7 02-07-2008 11:01 AM
speaking of tranny noises... Chuck Tow Vehicles 12 05-02-2007 11:24 AM
weird!!! rebel beck Plumbing - Systems & Fixtures 8 06-29-2006 09:06 AM
Not trying to be noises ,But Angel73 Insurance & Claims 0 05-28-2006 11:21 PM
