Old 08-29-2010, 08:09 AM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Question VTS Repro teardrop marker lights- what's the deal?
I recently installed some of VTS's teardrop marker lights ( Teardrop Marker Light ) on a small Scotty trailer project and I have already been gifted some to replace the marker lights on the Airstream Bambi II. What is the deal that these do not have a foam seal between the lens and the base???
This seems to be their only downfall as they are priced right, the aluminum base is way better than steel, and they look and fit just right.
I am thinking of using some foam material I have around here to make some gaskets. My buddy washed the Scotty the other evening, and the marker light fixtures took on lots of water. This can't be good from a corrosion standpoint.
Has anybody made such gaskets before? Any recommendations on materials?
Thanks! Ben
PA BAMBI II is offline   Reply With Quote
Old 08-29-2010, 09:40 AM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
I wondered the same thing when I Installed them on my 64tw,but busy fixing other things so the coach has not been out of the garage or gotten wet. Maybe they are designed for water to drain out quickly. If I did use a gasket it would only be on the top and sides so if the gasket fails water can escape out the bottom. I would think foam or thin cork.
kevin
kevinb is offline   Reply With Quote
Old 08-29-2010, 09:53 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I used black gasket sheet I got from an auto parts store.
Old 08-29-2010, 10:08 AM   #4
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
I made a gasket for the scare light on our unit out of cork. Used the old gasket which was in three pieces as a template. The cork was exceptionaly thin (like 1/8") and has done the job flawlessly. Worth adding that this was the kind of cork with an adhesive backer on it so it made it easy to position and hold in place while you put the lens back on. I got it at Lowe's--peel and stick cork panels. Cheap, too.
Good luck.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Teardrop Marker Light toastie Lights - Interior & Exterior 5 02-23-2008 09:02 AM
Marker Lights 1953 Flying Lights - Interior & Exterior 3 01-24-2007 08:41 PM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 12:46 PM
Marker lights nyrabbit Our Community 6 06-20-2006 08:07 PM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
