Old 01-20-2009, 02:48 PM   #1
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Voltmeter
"Is there a good reason why I shouldn't install a voltmeter. I'm thinking of installing it near the 12 volt panel while I'm re-wiring the panel.
Also, does anyone have a readable wiring diagram for my '76 International? Long ago I purchased a repro service manual but the image is so poorly duplicated it's impossible to follow.
Stone Ridge is offline   Reply With Quote
Old 01-20-2009, 03:19 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Aesthetics should guide your final decision. My factory, DC voltmeter is accessible only after opening a cabinet door. I like it that way.
I check AC voltage with a hand-held multi-meter as required.
Tom
Old 01-20-2009, 03:52 PM   #3
We would be glad to FAX you a copy, of the schematic.
You could PM the number.
Old 01-20-2009, 04:08 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Stone Ridge,
Which model do you have? I have attached a scan of the rear bath 12volt wiring for you. If you have the rear bedroom, let me know and I can pass that one along too.
Aaron
File Type: pdf 76 12v Electrical International rear bath.pdf (61.9 KB, 87 views)
WBCCI #XXXX AIR #2495
Old 01-20-2009, 04:30 PM   #5
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Plugin type
You could get something like this for VAC or something like this for VDC. When you don't need them keep them in a draw out of site.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-20-2009, 06:23 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My 71 has a OEM dial to check the battery. It still works. It does not have the numerics of voltage but I assume it is a voltmeter. It reads Good/ Fair/ Low
Old 01-20-2009, 07:16 PM   #7
1976 31' Sovereign
1963 16' Bambi
Thank you all for your input. I am going to mount it on the 12 V fuse mounting panel, behind the access door. Thanks again.
Digital Panel Voltmeter source wacnstac Batteries, Univolts, Converters & Inverters 13 05-30-2007 06:50 AM
voltmeter ALANSD Mechanics Corner - Engines, Transmission & More... 10 07-06-2002 08:13 AM
