Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-12-2009, 12:19 PM   #1
reggiemon's Avatar
Profile:  1959 18' "Footer"
Corpus Christi , Texas
Smile Vintage Tail Light Blasphemy
Well I just had to do it!
Couldn’t leave well enough alone when I saw the new 20 LED Stop/Turn/Tail lights for $36.99 a pair. Red Round 20 LED Truck Trailer Stop Turn Tail Lights:eBay Motors (item 140325319156 end time Jun-16-09 02:22:55 PDT)
Could they really be the right size to fit into the Bargman wedding cake lens?
1959 "Globester"
reggiemon is offline   Reply With Quote
Old 06-12-2009, 12:26 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Interesting. So, are you thinking about placing this inside of the Bargman 99 lens? Or is this for the Bargmen 6/11?
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 06-12-2009, 12:29 PM   #3
reggiemon's Avatar
I got them in AND........
Here we go....
ID:	82170   Click image for larger version
1959 "Globester"
Old 06-12-2009, 12:32 PM   #4
1960 18' "Footer"
Oh! That's very cool and something I will use. Thanks!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 06-12-2009, 12:32 PM   #5
Profile:  1977 27' Overlander
1963 19' Globetrotter
naples , Florida
Let us know if they will fit,I must park my trailer out in the swamp to keep zoning off my butt. Dave
OK,you answered it,I`m a slow typer. Dave
easyride is offline   Reply With Quote
Old 06-12-2009, 12:35 PM   #6
reggiemon's Avatar
Well it was a very close fit!
But not perfect…..I had to enlarge the mounting holes slightly in the new lens for them to match the Bargman lens screw posts. See the last picture.
ID:	82173   Click image for larger version
1959 "Globester"
Old 06-12-2009, 12:39 PM   #7
reggiemon's Avatar
Bear with me!
The installation is complete and I am very happy with how it turned out. It is not simple as the post of the new tail light extends thru a hole you have to cut in the tail light housing & trailer!
I will also show how I converted the license plate lite & clearance lights to LED.
1959 "Globester"
Old 06-12-2009, 02:41 PM   #8
reggiemon's Avatar
The thickness of the new tail light outer flange works well as it will act as a spacer to prevent the outer lens from being screwed down so hard that it cracks the lens. Reportedly a common problem.
Ok, so we need to remove the bulb holders from the light base plate.
Drill out the rivits!
1959 "Globester"
Old 06-12-2009, 08:11 PM   #9
reggiemon's Avatar
Smile
After the bulb holders were removed I saved the bases for cleaning the rust off & repainting. Here's what the license plate light assembly looked like. It is a Hollywood Accessories Model D42 model which is not available anymore.
ID:	82186   Click image for larger version
1959 "Globester"
Old 06-13-2009, 10:33 AM   #10
reggiemon's Avatar
After seeing the only license plate light replacements available, I decided I really wanted to restore this one.
LED?
Here is what I decided to try to convert.
White LED Truck RV ATV Trailer License Plate Light:eBay Motors (item 140326561215 end time Jun-21-09 21:04:35 PDT)
1959 "Globester"
Old 06-13-2009, 10:39 AM   #11
reggiemon's Avatar
Another picture of the existing old light assembly.
AND
The new LED light assembly, "disassembled"
Hang in there Ladies & Gents cause I will get back to the tail lights!
ID:	82209   Click image for larger version
1959 "Globester"
Old 06-13-2009, 10:46 AM   #12
1960 18' "Footer"
VTS has two replacment sizes like the one you have. License Plate Light Bracket - Smaller. I see from the next post you have it covered.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 06-13-2009, 10:57 AM   #13
reggiemon's Avatar
When I started this all of my focus was getting better lighting for safety reasons. I had no idea I was going to find the beginnings of significant corrosion under all of the exterior lights.
I took the time to clean up the corrosion & rust stains and I would reinstall the light fixtures with neoprene gaskets and Vulkem. In the end, this seems as important as the light upgrade!
ID:	82211   Click image for larger version
1959 "Globester"
Old 06-13-2009, 11:00 AM   #14
reggiemon's Avatar
Thumbs up
VTS has one larger (shape is very different) and one smaller (same shape as the one I have but smaller)
1959 "Globester"
Tail light housings ranchmink Lights - Interior & Exterior 10 09-08-2009 10:31 AM
Tail Light Gaskets Twinkie Lights - Interior & Exterior 6 07-22-2008 10:21 AM
Tail Light Always On blueline Lights - Interior & Exterior 2 05-05-2007 04:55 PM
Tail light wiring? LI Pets Electrical - Systems, Generators, Batteries & Solar 5 10-17-2006 09:12 AM
a magical tail light Charming Wino Electrical - Systems, Generators, Batteries & Solar 5 04-03-2004 03:19 PM
