Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-13-2009, 05:33 PM   #29
mello mike's Avatar
Profile:  1972 31' Sovereign
Phoenix , Arizona
Images: 14
SWEET!!! Very Nice!!!
Can I do something similar for my '72? Lighting is way down on my priority list, but it is something I want to do eventually.
Sterling - 1972 Sovereign Intl (RB)
Eddie - 2003 Ford Excursion (6.0L PSD)
Prodigy Brake Controller / Equal-i-zer Hitch / Honda EU2000i x2
Airstream Life Contributor
WBCCI 4CU #5661/AIR #5661
My Refurb Blog: UPDATED!!
http://mellomikesairstreams.blogspot.com/
Part wanted: 70s Kitchen Counter Unit
mello mike is offline   Reply With Quote
Old 06-13-2009, 07:33 PM   #30
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Most excellent!! Thanks for sharing your progress and results. One day I'll get to this. Can you also post how the license plate light looks as well?
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 06-13-2009, 07:43 PM   #31
pbearsailor's Avatar
Profile:  1957 22' Caravanner
Blaine , Washington
I just got tail lights from the same vendor, really good service and quick shipping. You pushed me over the edge on the clearance lights and I'll do it the same way.
Looks really good.
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 06-13-2009, 07:54 PM   #32
Profile:  1961 19' Globetrotter
1959 18' "Footer"
santa cruz , California
very nice job reggie. way to protect your sweet trailer with super bright LED's. can we call you 'LED reggie'? or reggie 'LED' mon?
you could have your airstream LED's hooked up to a switch at the door, and just turn those lights on for lighting in your garage
dont get too crazy, like some truckers you see on the road with rows and rows or LED's like christmas lights
greenrig is offline   Reply With Quote
Old 06-13-2009, 08:59 PM   #33
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
Originally Posted by reggiemon View Post
Next step was to connect all the wiring & new tail light assy.
(Kevin, aren't you glad I didn't string this out for days!)
What an LED tease you are!!!
Hey...All seriousness aside, they really do look good. Thanks for giving us a peek!
Experience can be a difficult teacher...You usually get the lesson first...And the instruction afterwards...
Old 06-13-2009, 11:18 PM   #34
reggiemon's Avatar
Profile:  1959 18' "Footer"
Corpus Christi , Texas
Thanks much for the kind remarks. I appreciate them.
Well I guess I need to admit to the old vintage round rights I have added to the interior. LED of course!
For flyfshr
Another picture of the license plate light. I'll get another picture with the external housing on it. I am debating on sealing the chrome housing with a small bead of black silicone run up against the old rubber base.
The tail light project would have been closer to a simple project if the new light did not have the plastic wiring stub sticking out the back so far. Having to cut a hole in the center of the base metal housing and AS skin pushed it out of the simple range BUT I still consider it very much worth the extra work.
I also felt that the total cost of the LED's was reasonable.
ID:	82265   Click image for larger version
1959 "Globester"
reggiemon is offline   Reply With Quote
Old 06-14-2009, 09:52 AM   #35
reggiemon's Avatar
Steve
When you trim the mounting ear off the clearance light be sure to trim only to the end of the mounting tab. That way you do not break into the sealed case. Thats one of the features I liked about these units, being sealed & potted (all except the license plate light and I sprayed it with a coating to protect it.
BTW These units are made in the USA
Another thought on the tail light mounting.
I just held the new tail light assy and put the lens on with the other hand & then put in the screws. It lined up well enough to be only a mild juggling act.
You could actually glue the new tail light unit into the lens to where it is one unit. That way it would be easier to take on & off
1959 "Globester"
Old 06-14-2009, 12:01 PM   #36
Blaine , Washington
Thanks for the tip, Reggie. Got the clearance led's ordered last night.
Old 06-20-2009, 04:35 PM   #37
reggiemon's Avatar
This is for FLYFSHR.
Here are pictures of the license plate light assy. I am going to tweek the LED block some to see if I can direct more light to the plate. I am not very happy with how much light is on the plate. The rubber base turned out good & thats what these pictures show.
ID:	82634   Click image for larger version
1959 "Globester"
Old 06-20-2009, 09:43 PM   #38
Blaine , Washington
I've got mine on now too. Still got my Bargman 9's and might try to do something with them as LED's later but they'll need a lot of work.
Thanks for pushing me into doing the marker lights, Reg!
ID:	82653   Click image for larger version
Old 06-20-2009, 09:53 PM   #39
flyfshr's Avatar
Phoenix , Arizona
Looking good Reg. Thanks for posting. How much light is thrown on the plate currently and how do you plan on making it brighter?
FF
WBCCI/VAC #2699
Air #10
Old 06-20-2009, 09:55 PM   #40
flyfshr's Avatar
Phoenix , Arizona
Looks like you need to get those Olympic rivets shaved on your marker lights.
FF
WBCCI/VAC #2699
Air #10
Old 06-21-2009, 10:06 AM   #41
reggiemon's Avatar
Smile
FLYFSHR,
I plan on adjusting the LED bracket to point the LED's more toward the plate. I think I can also move the LED assy to the outer edge of the bracket also, I'll let you know. I'm finishing up wiring/plumbing of the A/C currently as well as DC wiring inside. Trying to get to a point to go camping in Colorado in July.
Steve,
Glad you found something useful in my posts. What dia is your Bargman 9 tail lights? That place has a unit without the outer refelector ring that may work. Read your blog! Hang in there!
Guess you & I need to share a shaver........
1959 "Globester"
Old 06-21-2009, 11:59 AM   #42
Blaine , Washington
Yup, a shaver is on my list.
I think the Bargman 9's are right around 4", but they sit on top of the trim ring. I'll look and see what's possible for them down the road. For now, those on there look pretty good and at least I'll have working lights when I take it down the road to the welder this week. Really happy with the service from that eBay vendor you linked, too. Ordered those marker lights and had them 3 days later.
Tail light housings ranchmink Lights - Interior & Exterior 10 09-08-2009 10:31 AM
Tail Light Gaskets Twinkie Lights - Interior & Exterior 6 07-22-2008 10:21 AM
Tail Light Always On blueline Lights - Interior & Exterior 2 05-05-2007 04:55 PM
Tail light wiring? LI Pets Electrical - Systems, Generators, Batteries & Solar 5 10-17-2006 09:12 AM
a magical tail light Charming Wino Electrical - Systems, Generators, Batteries & Solar 5 04-03-2004 03:19 PM
