Old 11-04-2010, 01:07 PM   #1
1978 28' Ambassador
Savannah , Georgia
Vent micro limit switch problem
Tried this in another area and got no response so am reposting my question here.
Resealed outside exhaust vent. First the fan worked, then didn't, then did and now doesn't. Think the problem is the micro limit switch. Can I disconnect one of the two wires and touch it to the other wire to see if this is the problem? Can hear it click when lever is depressed. Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 11-04-2010, 01:14 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Yes, you can short the wires together and see of the fan comes on. I have seen micro switches at well stocked Radio Shacks. They may have the one you need. They can click and not work. The contacts inside arc and covered in carbon over time.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-04-2010, 01:18 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
No problem touching the wires together.
I had intermittent switches in the TW and replaced them. They acted like yours do.
Replacement is easy. Getting the adjustment right was tricky on the roof vents.
Good luck,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 11-04-2010, 01:35 PM   #4
1978 28' Ambassador
Savannah , Georgia
Thanks for the quick replies. Undid one wire and touched the other. Nothing happened. Will get out the voltmeter and see if there is power coming through. Will be mad at my self if it is just a fuse! Started to rain and will have to wait until tomorrow. What readings should I get on the wires going to the micro switch? Thanks.
Old 11-04-2010, 08:30 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
Just checked my wiring diagrams to confirm my recollection at seeing sparks.
All the switches in my Ď72 are wired in on the hot side. My diagram shows the fan and lights at the roof vents and range hood feed off the fuse panel by the converter.
Theoretically if youíve got lights you should have power at the switch. Practically after 30 plus years any number of connections could be bad. Donít forget that even if you have 12 volts static on a switch, you could have a voltage drop or bad ground anywhere in the circuit once the load is applied.
Good luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Old 11-05-2010, 05:45 AM   #6
1978 28' Ambassador
Savannah , Georgia
Will do some more investigation today. Noticed that there is a bundle of wires under the filter. Have two 3-way switches that are supposed to control the galley lights. Will take pictures of current switches and wires. Am at a total loss when it comes to electricity. Maybe this stems from my sister getting me to stick a knitting needle into a socket when I was 5! Even a 12 volt potential shock still scares me. Thanks for all your advice.
Old 11-05-2010, 09:42 AM   #7
1978 28' Ambassador
Savannah , Georgia
Yay! Found the problem. One of the wires from switch to fan motor had a faulty connection. Stripped wires and used wire nut to connect. The fan and switch both work. Now if I can only figure out how the 3-way switches work. Thanks for all the help and advice. Noticed some other wires were connected with oversized wire nuts and then taped to keep them secure. Pulled on each wire and have found two that easily separated. Used proper size wire nut and they are now secure. Did final adjustment to micro limit switch for opening the vent and all works great. Now to eat some beans to check it out!
Fantastic Vent reverse switch bolerama Roof Vents, Skylights & Fans 77 03-24-2012 08:11 AM
vent fan dimmer switch jimirwin Electrical - Systems, Generators, Batteries & Solar 4 09-15-2010 11:31 AM
Micro/Conv problem tport40 2007 Safari SE 4 10-07-2007 11:16 AM
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-12-2006 11:11 PM
Breakaway switch problem SilverToy Brakes & Brake Controllers 5 03-27-2006 03:56 PM
