Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 10-24-2019, 06:15 PM   #1
2015 25' FB Flying Cloud
Huntley , Illinois
Using external power connection adapted to 20 amp
We are storing where we can connect our external 50 amp outlet and converted to 20 amps for 3 hrs a day for charging the batteries. So as we thought this through. Our 2018 serenity has a battery disconnect switch inside the door. We have pondered back and forth. If we switch off the battery connect switch inside, will our battery still charge as we are hooked to power. Logically we thought no but hey. We would like the answer we know thar for storage to use the battery disconnect. We have not had the current situation.
Thanks in advance
cegardner is offline   Reply With Quote
Old 10-24-2019, 07:07 PM   #2
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
On page 5-8 in your 2018 owners manual the answer is clear.
https://www.airstream.com/wp-content...manual-178.pdf
Alan
Old 10-24-2019, 07:13 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
No. If you switch off the battery disconnect your battery will not be charged by the converter.
wulfraat is offline   Reply With Quote
'04 Safari- what does the external cable connection energize? DJW 2000 - 2004 Safari 5 06-13-2011 02:23 PM
'04 Safari- what does the external cable connection energize? DJW Audio, Video & TV 0 06-02-2011 08:35 AM
Int'l Bambi 19' External Propane Connection? jambie 2005 and newer - Bambi all models 1 03-06-2011 07:28 PM
external water connection? pickerdd Fresh Water Systems 5 10-07-2009 01:08 PM
External Antenae Connection Raptorrider2001 1997 - 1999 Safari 9 01-12-2003 10:02 PM
