Old 05-02-2015, 08:54 AM   #1
1972 23' Safari
Burlington , Kentucky
Urgent Help....No Brake Lights when running lights are on
Doing my checks before we head out in the morning and the brake lights don't come on when the running lights are on...UGH...
So... hare's what I have checked....
1. with the headlights OFF...everything works...BUT only on the big filament. the small one doesnt come on at all...
2. when the headlights are ON...everything works BUT the brake lights... and again ONLY on the large filament...
That said... when I rewired and added the new tail lights I checked everything using a power source and things worked...
Question...
1. Do I have the bulb wired backwards? can I just switch the wire at socket?
2. Bad connection in 7 way or cable
2. 7 way wired wrong at the trailer?
Since I have kept the original connector on the trailer I did have to move a couple wires to match my 2005 F150...and here is what I have
Trailer
1 (12 oclock) = pos.
2 (2 oclock) = RT stop turn
3 (4 oclock) = Brakes
4 (6 oclock) = Neg.
5 (8 oclock) = LT stop turn
6 (10 oclock) = running lights
7 (center) =back up lights
URGENT!!!HELP HELP HELP...
Debnw is offline   Reply With Quote
Old 05-02-2015, 09:52 AM   #2
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
This may not be your problem but I was having strange things happening with my lights and after using a voltmeter to test everything I found that one of the tail lights did not have a good tight ground.
Who would have thought that one bad ground on one light would have caused other lights to act different.
Judging a person does not define who they are, it defines who YOU are.
GeocamperAS is offline   Reply With Quote
Old 05-02-2015, 10:01 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I am guessing since you've done all this yourself that you have a 12v tester. I would start there. Go through the set up on the truck, run through the whole series with someone in the drivers seat. Lights, turns brakes etc. If that checks, then I'd hook up and with the 7 way on the trailer connected but loose enough so you can get the 12v tester with the needle nose pointer into the or on the wires and a good ground run through the tests again. I am going to guess you've got wiring wrong someplace OR a poor ground.
These are always frustrating beyond normal frustration. Best of luck
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 05-02-2015, 10:06 AM   #4
1974 Argosy 20
Kooskia , Idaho
First, pull your cord out of the socket on the TV several times. Spray with contact cleaner if you have it.
Second, if that does not work, look for ground issues at the tail lights. Also look at the bulbs and sockets to be sure they are all in excellent and clean condition. Very often the problem is there.
You didn't mention if the trailer running lights work. Are they working when the rear tail lights should be on? If so, I would again suspect a grounding issue. However, these things are hard to diagnose from afar.
Old 05-02-2015, 10:35 AM   #5
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Another strong vote for contact cleaner here. While towing one day we suddenly got a warning on our dashboard that said the brake controller was no longer connected to the trailer. Everything else looked ok and the running lights were working, so at first we were stumped. Then we whipped out the spray can of contact cleaner we had stocked in our "just in case" bin, and generously sprayed the umbilical as well as the connector on our truck. After waiting a moment or two, I shook the remaining cleaner fluid out of the umbilical and re-connected it to the truck. Problem solved, with zero recurrences!
Thank goodness we had read the forums months ago and added that can of spray cleaner to our stock. Otherwise, we would have been afraid to tow beyond the bare minimum required, at very low speeds, to get us to some kind of repair shop to figure out what on earth had gone wrong.
Rocinante is our 2014 International Signature 27FB
Old 05-02-2015, 04:53 PM   #6
2007 22' International CCD
Ground connection somewhere is loose. Check starting where the umbilical joins the AS wiring and work back from there. The brake lights work when the running lights are off because the running ljghts are providing some ground to the brake lights when off.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 05-02-2015, 05:56 PM   #7
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Question...
Trailer
4 (6 oclock) = Neg.
Hi, I have seen this before; If your brake/turn light filament is connected to your running lights, the dimmer running light filament won't show with your brake lights on. But the dimmer brake lights [on the wrong filament] will show with everything else off.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-02-2015, 07:12 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The brighter filament is the brake light filament.
You can safe yourself many trips to the back of the coach by using the emergency flashers to check brake lights. Also turn signals. Just make sure left is left and right is right.
Old 05-02-2015, 09:05 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
So yes,,,, you have the new lights wired backward.
Swap places on the two wires going into the can.
I guarantee my answer to be 99.97 percent accurate.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-03-2015, 06:50 PM   #10
Binghamton, New York , New York
Poor Connections
If you've put a volt meter on the outlet (7) plug connector and it is working. Remember, it won't work unless brakes and all other lights are on, I would spray contact cleaner in both receptors. The little contact connector latch on top of the tow vehicle tends to pull the connection upwards. I don't trust the damn thing and I wrap a small bungee around the neck of the cord of the vehicle to the frame of the truck. It holds the the connection square with the vehicle and poof, problem gone. Hope this helps. I doubt your problem is serious.
Pursuit 97 is offline   Reply With Quote
Old 05-08-2015, 03:04 PM   #11
Dan@LED4RV's Avatar
Denton , North Carolina
Question...
Trailer
4 (6 oclock) = Neg.
I know you may have figured this out by now but the threads live a long time. I thought I would post the picture.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 05:20 AM
'90 Limited 34' (Axle and shock replacement) URGENT HELP PLEASE Elf1 Axles 2 02-21-2010 08:20 AM
454 Carb Help, URGENT-We're on the road... gypsychris Mechanics Corner - Engines, Transmission & More... 5 10-30-2008 07:58 PM
Urgent help needed baltimore remcolent Shipping & Export/Import 71 08-14-2008 10:28 PM
