Old 06-27-2012, 03:39 PM   #1
bgordon's Avatar
Austin, TX & , Colorado
Images: 32
upgrading 1156/1157 socket - led w/ wires?
Hi all-
I'm fixing up my running lights and am using the existing glass lenses/bases.
I'd like to make the lighting more reliable and am interested in using LEDs. My primary design change would be to have a ground wire to the lights rather than relying on the base itself for ground.
I was thinking that an LED light with pigtails for brake/clearance/ground would be ideal if it would fit in the existing base. Or is there a way to convert the 1156/1157 base to a more modern connection?
Any leads?
bgordon is offline   Reply With Quote
Old 06-27-2012, 03:57 PM   #2
bgordon's Avatar
Images: 32
From looking around a bit, I think the best bet would be a new 1157 socket w/ a 3 wire pigtail (signal/marker/ground).
Haven't nailed one down yet, but I see that it is an available option.
Old 07-02-2012, 09:47 PM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
bad ground
Originally Posted by bgordon View Post
Hi all-
Any leads?
B Gordon
About 95% of all unreliability of lights could be traced to a bad ground, as I'm sure you know. Corrosion from the socket, then to the can, the can to the base, the base to the body, and then the ground on the other end. Rebuilding the sockets or replacing the cans, then cleaning up those connections would be the best way.
I have seen where a ground wire was run straight to the frame to improve the circuit. It was fished down threw and inside the wall.
In some cases LED lights could be straight wired but one would have to be careful when it comes to LED lights. Some of them have drivers and resistors in the sockets to lower the power to allow the LEDs to handle the power.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 06-25-2013, 05:59 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
1157 LED replacements
Has anyone found an LED replacement for the 1157 tail/turn/stop bulb?
Old 06-25-2013, 09:06 PM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
There are lots of vendors for 1157 led bulbs, but they are still pricey. A quick search will turn up dozens of them. The main problem seems to be that the fixtures aren't designed for directional sources.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
