Old 09-23-2015, 08:31 PM   #1
Arlington , Virginia
Undercarriage Lighting AI Grand Tour
On my 2016 Airstream Interstate Grand Tour, when I turn on the main disc switch located just inside the sliding door by the water heater switch (the switch that powers up electric and allows lights and so forth to be turned on) the undercarriage light that runs from wheel to wheel under the step at the side sliding door turns on. I cannot turn the light off and the dimmer also does not respond with the buttons on the passenger seat labeled "chassis." When parked at a campsite this exterior light should be able to be dimmed or shut off in a case of courtesy to adjacent campers. Does anyone know how this operates? I don't see anything about this lighting in the owners manual. Thanks.
xCliff is offline   Reply With Quote
Old 09-23-2015, 09:09 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I don't think any other Interstate even has undercarriage lighting, only the Grand Tour.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-02-2015, 12:03 PM   #3
Figured it out ... part of the light fixture was leaning against a metal part of the vehicle. This caused it to remain on and not respond to the remote off/on/dimmer switch.
Undercarriage Rehab Del Gurney Jacks, Stabilizers, Lifting and Leveling 18 07-25-2013 07:56 AM
Axle bent rubbing on undercarriage Modern South Axles 9 03-29-2013 09:38 PM
Winter Overhaul of 1968 GT undercarriage Randy Gates 1965 - 1969 Globetrotter 5 05-10-2011 08:10 PM
Airstream Undercarriage Rustproofing Mifair Axles 3 11-21-2010 08:26 AM
2007 Safari undercarriage valves woodedareas Plumbing - Systems & Fixtures 3 05-13-2007 02:28 PM
