Old 01-13-2017, 06:44 AM   #1
The Colonel's Avatar
2017 25' Flying Cloud
Florence , Alabama
Under camper accent lighting
I'm thinking of attaching some sort of led accent lighting under trailer. Not comfortable with drilling holes to mount support without knowing what's behind skin. I'm thinking about using four or so strip lights. I would attach strips with rivets.
DBLee and Southern Belle on the road
The Colonel and Southern Belle
The Colonel is offline   Reply With Quote
Old 01-13-2017, 07:42 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Ok, post some photos when done.
MICHAEL
Old 01-13-2017, 07:51 AM   #3
Florence , Alabama
Any help with finding safe spots to drill
Old 01-13-2017, 12:55 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
For mount points? One string down center? Just a bit fore or act of belly pan rivets. I think after would be best.
Along each side, same. Just an "awl" may punch a nice clean hole.
Make sure you don't punch try any "tanks".. running on port and starboard would minimize that potential....
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-13-2017, 03:45 PM   #5
Florence , Alabama
Good points, no pun intended. I'll sort it through once home and can take my time to check it all out. Thx
Old 01-14-2017, 11:12 AM   #6
kaylorsan's Avatar
2012 Interstate Coach
Park City , UT
Try doublestick tape
3M makes a great doublestick tape call VHB (very high bond). There are different thickness of it to adapt to surface conditions.
I have 3 big solar panels on my roof that are held on with nothing more than the VHB. They've been on for about 2 years now thru plenty of heat and freeze/thaw cycles, in addition to high winds and highway speeds.
kaylorsan is offline   Reply With Quote
Old 01-14-2017, 11:15 AM   #7
Journeyman
2016 25' International
Amherst , Massachusetts
I think there is also UHB (ultra high bond) tape available.
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 01-14-2017, 12:21 PM   #8
Watertown , Massachusetts
So cool!
That would be so cool to have led lights under! I'm assuming they need a wired power source. How /from where do you plan to run the power?
sallye is offline   Reply With Quote
Old 01-14-2017, 12:41 PM   #9
Silver Xanax
1991 29' Excella
Smiths Station , Alabama
LED accent light
I used 120 VAC LED rope lights. Fasten to belly pan along frame with tie wraps and 1/2" stainless screws. Power and dimmer switch inside storage compartment.
delmer is offline   Reply With Quote
Old 01-14-2017, 12:56 PM   #10
Florence , Alabama
Haven't sorted that out yet. I kinda need the kit in front of me, laid out where it will go then try to find a way to power without much invasion of skin.
Old 01-14-2017, 02:24 PM   #11
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
DB-
I did ours with an inexpensive 12v blue rope light string from amazon that came with a cheap vhb tape attached to the back of the string. I also ordered a 12v controller with remote that lets you do effects and adjust the brightness remotely. You could do an rgb string if you want more color.
I wiped the sides of the underbelly tank enclosure down with rubbing alcohol on our 27fb and stuck the rope lights on, completely covering 3 sides of it. I just bent the string around the corners, and if I lost 1 or 2 leds with the bend no big deal. I ran a 12v line to the battery box on the tongue and put the receiver there behind a fuse holder.
Easy, inexpensive project they gives us a cool blue glow under Pete wherever we camp! Hope this helps.
ShinyPete is offline   Reply With Quote
Old 01-14-2017, 04:23 PM   #12
GR8DANE's Avatar
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern , Minnesota
Check out the VAP on YouTube for Tim's video. I've got two led strips running around bottom of my '54. 12 volt system soon to be music controlled. Also have a remote for dialing up colors. Inexpensive and tre cool.
VHB 3M tape works great!
GR8DANE is offline   Reply With Quote
Old 01-14-2017, 04:58 PM   #13
Florence , Alabama
I'll try the tape. I have a 7 color led light kit with 4 strips and RC coming. It also syncs with music, but not sure I'll use it. May add a couple more strips if it needs it.
Old 01-15-2017, 03:59 AM   #14
jamieb1086's Avatar
2016 25' Flying Cloud
Selbyville , Delaware
I've seen it under a 34' Airstream. Looks awesome! Gotta admit I'd love to do it too!
jamieb1086 is offline   Reply With Quote
Old 01-15-2017, 02:28 PM   #15
Journeyman
Anybody who had done this have pictures?
Old 01-16-2017, 06:59 AM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Blue LED lights glowing under the trailer would be awesome.
I have thought about it quite often, but haven't done anything yet.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-16-2017, 09:30 AM   #17
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I mounted leds they sell for motorcycles, 4 to a block, 5 blocks. VHB to a bracket (cut up license plate) to set angle, then VHB to the belly skin. Tied together with cheap speaker wire, soldered connections, wiring secured with VHB wire clips, to the battery box. I leave them on full time unless I'm on battery only.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 01-20-2017, 06:09 PM   #18
2021 16' Bambi
2021 22' Bambi
North Port , Florida
Name:	ImageUploadedByAirstream Forums1484960951.193647.jpg
ID:	278479Click image for larger version
Name:	ImageUploadedByAirstream Forums1484960963.646056.jpg
Been thinking about this myself. Mocked up the lights this evening. I like!
cliffcharb is offline   Reply With Quote
Old 01-23-2017, 01:50 PM   #19
Florence , Alabama
Nice, got my light set in and just stuck them on underneath to get an idea if on set would do. The set has four strips, two @ 48" and two @36". Last night it looked good enough, I'll stay with the one set. Move camper tomorrow and will install in the next few days. I'll take pics once done.
From dblee50 and Southern Belle on the road
Old 01-23-2017, 04:54 PM   #20
Florence , Alabama
Here are few shots of the mockup. Pretty pleased, plan to go fwd with install. Not sure I can trust tape underneath, so have to sort that out.
Review - CCD Dinette Cushions by Accent Upholstery Stephen Mick Upholstery, Blinds, Walls & Interior Finishes 20 06-04-2020 08:12 AM
Interior Accent Lights Frank&Mike General Interior Topics 32 11-26-2014 06:37 AM
Clearcoat?! lifting on Accent strips.... SilverToy Clearcoat, Exterior Paint & Trim 3 10-18-2005 08:05 PM
Blue Accent lines boltos Clearcoat, Exterior Paint & Trim 2 03-24-2004 10:41 AM
