Old 08-05-2010, 07:26 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Umbilical cord
I need to replace trailer wiring in my resto.What is the ideal size for the different colored 7 wires?
bwaysteve is offline   Reply With Quote
Old 08-05-2010, 08:48 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Eight foot.
Old 08-05-2010, 08:49 PM   #3
5 wires at 12 or 14 guage.
2 wires at 10 guage.
The correct 7 way cable is readily available.
Old 08-05-2010, 09:26 PM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I mean gauge.
Old 08-05-2010, 09:36 PM   #5
Splitrock's Avatar
I mean gauge.
I bought a molded end cord (8' long:-). The 12 volt wire and the ground is 10 gauge and the light wires look to be 14 gauge. The brake wire might be 12. When I wired my 7 way to the fuse panel, I used #10 for the 12 volt, the ground, and the brakes. Everything else I used 14.
Gary
Old 08-05-2010, 10:20 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
What Andy said.
The umbilical is short and wire gauge isn't that critical except maybe for the charge line and ground if you're trying to get the battery in the traylah to charge while under way.
So, the turn signals, and backup lights, for instance, any gauge is fine, you could run 20 gauge and never notice any problems. Brakes, for a tandem axle, 14 gauge though 16 will probably work, triple axle, 12 or 14 gauge. Tail and marker, if you have LEDs, 16 gauge is enough, 14 otherwise.
new umbilical cord crispyboy Electrical - Systems, Generators, Batteries & Solar 6 06-09-2010 07:59 PM
Umbilical Cord Replacement watt1968 Electrical - Systems, Generators, Batteries & Solar 5 06-13-2009 06:39 AM
Install new umbilical cord beginner5 Electrical - Systems, Generators, Batteries & Solar 7 07-09-2007 09:02 PM
Umbilical cord mickleton Electrical - Systems, Generators, Batteries & Solar 4 07-07-2007 10:25 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
