Old 07-04-2006, 09:02 PM   #15
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Originally Posted by ALANSD
my new to me f 250 has the 7 pin blade type connector, my new to me 78 AS has the bigger round connector....can't seem to find the pieces to make an umbilical yet, tried etrailer, Grainger, Northern Tool and other sites....and ideas?
Yes..
Buy a length of trailer cord, it's usually a mix of gauges and appropriate colors.
then get a 7-pin round for the trailer end, and a 7-pin flat for the car end, and use the Airstream wiring code on the round end, and the RV standard code on the flat end.
The Airstream code is on their website, the flat end's code is on the box the connector comes in, usually.
Uwe
www.area63productions.com
Old 07-04-2006, 09:08 PM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you mean change out the airstream end to the smaller modern plug style? The Soveriegn has the plug on the trailer to the left of the tongue, what happens to this covered plug...I am replacing the inside?
I did replace the flat on my 280 to a round..
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-04-2006, 09:23 PM   #17
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Nonono, leave the Airstream end intact, and leave the car end intact, just buy 2 different plugs, and connect the wires to the corresponding pins.
You can alos change the car end to a 7-round ( which is electrically superior), but then it won't for any other modern trailer plug.
Uwe
Old 07-04-2006, 09:29 PM   #18
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
ok sorry to be thick, but where the heck do I find the end to fit the airstream plug? That is the one I can't seem to locate. I can get a blade or round for the truck no problem...
AIR #005
retired!
Old 07-04-2006, 09:35 PM   #19
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
OK, hang on....
Here we go:
Connector:
http://order.waytekwire.com/CGI-BIN/...D4A072+M37+ENG
or, try # 37675
For the cord, try : WT 702
Actually, you might want to simply order their catalog. You will need wiring supplies, and theirs are good stuff.
Uwe
Old 07-05-2006, 03:15 AM   #20
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Alan,
Champion Trailers has everything you will need. Also look for a heavy truck store like Fleet Pride or possibly NAPA.
Aaron
WBCCI #XXXX AIR #2495
Old 07-05-2006, 12:07 PM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks guys, I am slow but I'm coming around.
Now how about my trailer hitch? The AS has the chains and those weight distribution stirrup things, and I have the receiver end with the two balls on it. I guess all I need is the bars. How do I go about figuring out what bars to get? I might find a name on the hitch but haven't yet.
AIR #005
retired!
Old 07-05-2006, 12:09 PM   #22
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Andy at Inland RV sent me his part # for the trailer plug also.
Found the plug and wire and all locally, as I was cruising for other parts. Now I just have to wire it up, I have the schematic.
AIR #005
retired!
Old 07-19-2006, 01:45 PM   #23
7 way round connector on 73 Ambassador
My 73 A/S did not come with the umbilical cord. I'm pulling with an 2003 Chevy 1500 that has the standard 7 way blade connector. Most of my research leads me to believe that I will need to remove the old round pin apparatus from the trailer and replace it with a blade. I would prefer keep the original in tact, buy a 7 way connector that will attach on the tow end with a pig tail on the other that I can attach a 7 way round to. Does anyone have any suggestions on locating a 7 way round connector that I can plug in on the trailer side? InlandRV.com has one (part #66266) for $11.50, but they want $15 to ship it. These do not appear to be readily available so I maty just have to grin and bear it. Any alternative suggestions, cautions or advice will be appreciated. I need to get this baby rollin'!
jd
jdwdwd is offline   Reply With Quote
Old 07-19-2006, 01:56 PM   #24
Hind-Sight's Avatar
Murray , Utah
I was shopping for parts at one of the local RV stores and saw one there. If I remember, the price was about the same as you mentioned above.
http://www.motorsportsland.com/
I have no idea if they ship or what they would charge.
If they won't ship, let me know and I am sure we can work something out.
Andy S.
Murray, Utah
69 Overlander
01 Suburban
Hind-Sight is offline   Reply With Quote
Old 07-19-2006, 01:59 PM   #25
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
jdwdwd,
Try a truck stop, I have seen the round pin plugs there.
Bill
Just my personal opinion
Old 07-19-2006, 02:37 PM   #26
Andy,
Thanks for the link to motorsportsland. They have a pretty complete selection of parts available online. They have a "Husky" product that enables someone with an original connector with round pins on both ends to convert from round to flat on the tow vehicle. It won't work for me because I need a female connector to plug into the trailer. I'm grateful for your offer to work something out in the event mail order was not available, very kind of you!
Bill,
I will follow up on your truck stop lead. Thanks!
Old 07-19-2006, 03:00 PM   #27
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
jd,
Couple of places to look...I bought mine from a local trailer specialist, they sell trailers and anything you could conceivably need for them. Another place would be somewhere that caters to the large trucks. In my area it is T&H Brake service, they specialize in heavy truck parts, possibly a heavy truck dealer would have them. IIRC mine was about $10.
Aaron
Old 07-20-2006, 01:49 PM   #28
Found what I was looking for, right in my back yard at a TRUCK STOP. Thanks for the help.
jd
Umbilical Wiring Diagrams thenewkid64 Towing, Tow Vehicles & Hitches 14 03-31-2009 12:03 AM
old stlye umbilical cord mrbeanpa Lights - Interior & Exterior 4 03-15-2006 11:37 AM
7-Pin connector problem mtnman Lights - Interior & Exterior 26 01-09-2006 04:25 PM
Rewiring Trailer Umbilical Plug DPeakMD Electrical - Systems, Generators, Batteries & Solar 4 02-29-2004 05:40 PM
Crushed Umbilical heyskipper Lights - Interior & Exterior 3 02-23-2003 08:23 PM
