Old 10-12-2010, 08:33 PM   #1
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Two overhead lights out
2007 Safari SE 20ft
The two overhead lights in the galley area are out. Any ideas? Seems strange that just these two are not burning. How do I remove the fixtures for checking? I can pull down on the rings but am not sure how to totally remove.
Silverbee is offline   Reply With Quote
Old 10-12-2010, 10:40 PM   #2
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I just did it tonight on my 2006Se25. You have to use a knife or in my case a small screwdriver and put it on the edge of the innermost ring. Pry very carefully as to not scratch and the inner lens will pop out. Be careful to keep a hand under it as the ring and glass could drop out. The bulb is a two prong small flashlite sized unit. I think its 10watts but I can't tell as I need a microscope to read it. Also use something besides your hands, I used a square or TP from the bathroom, to handle as the oil on your hands will toast the bulb.
RichHog is offline   Reply With Quote
Overhead lights not working... kevin242 Lights - Interior & Exterior 2 10-05-2010 07:42 PM
Overhead lights '79 Excella Engmgnt 1978- 1979 Excella 500 0 07-04-2010 10:49 AM
Bathroom and back overhead lights out RichHog Lights - Interior & Exterior 7 06-27-2010 09:45 AM
Overhead puck lights bernermom Lights - Interior & Exterior 13 10-10-2008 10:40 AM
have 110 receptacles no overhead lights michaelsessa Lights - Interior & Exterior 4 04-29-2007 06:45 PM
