Old 12-23-2009, 01:59 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Turning on Running lights while camping
So at the Blanco Rally a few of the Trailers had plug adapters that turned on all of the running and brake lights while we were camping. Made a nice addition and looked cool. I was told that all that's needed is a connector (TV side with the pins connected (soldered etc.). So can those of you in the know tell me which connector to buy and what pins to wire together, a general "how to" build or buy. Thanks
RichHog is offline   Reply With Quote
Old 12-23-2009, 02:04 PM   #2
VIKING's Avatar
Boulder Creek , California
Send a PM to Toddster. He made one that came to me with my Safari.
Rich the Viking
VIKING is offline   Reply With Quote
Old 12-23-2009, 02:07 PM   #3
Easy to do. You can make your own, by using a jumper wire between the charge line and the clearance light circuit terminals.
If you take the cover off the connector, those two wires would be the large blue wire, and the green wire.
Old 12-23-2009, 02:08 PM   #4
_
hiya 'hog
while it does depend on HOW the pigtail is wired (modern 7 pin vs something else...)
there are 2 eze ways 2 do this...
a flasher relay or a fusible link.
many threads and pictures of the gizmos have been posted.
start here and follow the LINKS inside.
http://www.airforums.com/forums/f447...cle-35786.html
http://www.airforums.com/forums/f447...-on-35681.html
see the 'automotive flashers' listed mid page here...
http://www.wiringproducts.com/contents/en-us/d35.html
and more on this...
http://www.airforums.com/forums/f447...ing-41775.html
cheers
2air'
Old 12-23-2009, 02:16 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Just connecting the terminals at position 1 and 11 o clock on your umbilical cord will do it.
As noted above a 2 prong car flasher will fit directly into these terminals and cause the trailer lights to blink, not the brake lights. If you solider 2 male spade connectors to a short piece of wire and insert that into these terminals the trailer light, not the brake lights will stay on.
Please note if your trailer has filament bulbs make sure you use at least a #12 wire because of the current, if you make your own.
2004 Excursion 4x4
Old 12-23-2009, 02:28 PM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
use an automotive in-line fuse holder....otherwise, there won't be any fuse protection on the circuit.
(under "normal" circumstances, the lights are fuse-protected by the tow vehicles fuses.).
I just crimped on a spade connector to each lead on the fuse holder, and stick one in @ 11, the other @1.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-23-2009, 03:17 PM   #7
2010 25' FB Flying Cloud
Davenport , Iowa
PLEASE DON'T---- The person parked behind me had his on all night and made it difficult to sleep. I had to hang towels over the windows to help reduce the flashing.
Rember your fellow campers; "and do unto others"
Airtandem is offline   Reply With Quote
Old 12-23-2009, 03:37 PM   #8
1972 29' Ambassador
Harrah , Oklahoma
Why didn't you ask him to close his window curtains.. oh wait, you were talking about flashing lights.
My Brain Project and Tech Notes
airbassador is offline   Reply With Quote
Old 12-23-2009, 03:38 PM   #9
VIKING's Avatar
Now if you had one of these you could have had light wars all night, and done to others as they be doin' to you.
Old 12-23-2009, 03:44 PM   #10
1958 22' Flying Cloud
1974 Argosy 28
1978 Argosy 24
Travelers Rest , South Carolina
LIghts at night
If you must turn on the lights PLEASE be considernate and turn them off by 8 or 9 PM. We have added room darking curtains and still fellow RV's insist on lights everywhere. How will you see the stars? Or sleep? We don't have any outside lights where we live and just the glow from the nearest town 13 miles away is distracting when you walk outside at night.
Richard & Linda
Tumbleweed ('78 Argosy)
Travelers Rest, SC
stillcove is offline   Reply With Quote
Old 12-23-2009, 04:12 PM   #11
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
One additional benefit from the flashing light setup is if you have to leave your trailer on the side of the road while the TV is disconnected. For instance, if the TV is not operating and the tow company can only tow the TV then the flashers will work off the trailer battery until you can return. Another example is if there is a need for emergency help in a campground and you call for assistance - your trailer can be the one with the flashing lights to identify yourself easily to the first responders.
I setup one that uses a 7-pin connector for a TV (female connector) on a 4" PVC endcap and all the electronics in a 6 inch piece of PVC pipe with another cap on the end. Works good and allows you to just "plug in" when you set up at the camp site - it has an on/off switch. Another benifit of using a female plug in is you protect your RV plug from damage.
PM if you want pictures. BTW - I set it up with a three way switch (On, Off, Flash) I got great advice from many people here on how to do all this - I can provide my wire diagram if you want.
Mike
ID:	92946   Click image for larger version
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-23-2009, 04:26 PM   #12
VIKING's Avatar
Cool slightly off-topic
I made black-out shades for my Safari, for using it at Burningman where
everything is 24/7. After one outing I decided to forego curtains altogether.
There will always be some inconsiderate people out there, and this really helps with both light and noise, and I don't have to rely on the good character of my neighbors to get a good nights sleep
Old 12-23-2009, 04:56 PM   #13
2011 25' FB Flying Cloud
Anywhere & , Everywhere
For those who don't feel up to building your own:
Plug-n-Light 5th Wheel Accessories
Have nothing to do with this outfit and have never used this product. Do know it was in Trailer Life. Unfortunately this unit just allows for steady light - it does not have the flasher option.
Al - K4GLU is offline   Reply With Quote
Old 12-24-2009, 09:30 PM   #14
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Here's another product... we have one. It's great and allows us to have the running lights and tail lights on (constant)... or to have the running lights on (constant) with flashing tail lights... http://www.westhaverassociates.com/flashcube/
TB & Greg and Abbey Schnauzer
#3954
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
Trailer running lights while camping henw Lights - Interior & Exterior 21 05-07-2008 11:55 AM
Turning on the lights 26.982 amu Electrical - Systems, Generators, Batteries & Solar 6 03-27-2006 05:42 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
