07-02-2014, 09:40 PM
#21
2006 19' Safari SE
Tucson
It does sound like something is going on with the umbilical cord ... or at least the plug itself... crossing two of the wires is the only way your running lights could remain on when it's not plugged into the tow vehicle.... Two of the wires are connected, allowing a draw from the trailer's batteries to power the running lights.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
07-04-2014, 07:15 PM
#22
2012 27' Flying Cloud
W
, New England
So I've wired a 7-pin connector to receive my trailer's 7-pin umbilical. I bought a 7-pin "male" connector, a pre-wired 12g fused wire that could take up to a 30a fuse and a 10a fuse to insert in to the fuse holder. I wired the ends at the 11 and 1 o'clock positions on the 7-pin connector. So basically, I should be able to connect my trailer's umbilical to this connector box and my clearance lights will be on.
Reading this thread, it sounds like people have done this with everything from a paperclip to a 10a blade fuse to raw wire to very complex switchable boxes for on/off/flashers. My question is, when I connect this, what are the odds I get a shock or fry the wiring in the trailer? I guess if folks have stuck paperclips in their umbilical and lived to tell the story should bode well for a more precise fit with an online fuse, no?
Also - there was a suggestion to do this when connected to shore power to not drain the battery. So no problem running those 12v lights while on shore power at the same time?
Thanks!
07-04-2014, 07:20 PM
#23
Oswego
Thanks!
No problem while on shore power. The converter will keep the batts up and the batts run the lights. BTW, I use a blade fuse..K.I.S.S.
-Rich-
07-09-2014, 06:49 AM
#24
1975 25' Tradewind
Sherbrooke
, Quebec
Umbilical cord.
Thank you for your input. It confirms what I thought.
I will take a look next week-end and try to figure it out.
Have a good day!
Ghislain
07-09-2014, 08:52 AM
#25
1967 20' Globetrotter
Englewood
We bought this last year. It works great and was only $15.
Camperlite | eBay
07-09-2014, 09:37 AM
#26
2004 16' International CCD
Chicagoland
Originally Posted by enived2
Thank you so much for sharing this. I just bought one to replace my home-built unit. You can't beat the price - I spent at least double this to build my own jumper setup. You can't beat the size of the Camperlite either.
07-09-2014, 10:18 AM
#27
2013 30' Classic
Greenwood
, Mississippi
I just stuck a short piece of wire in the battery charge and running light pins of the trailer plug- free- top 2 pins-
This is the method Dave Schuman, general manager of Airstream, recommended in a recent issue of Blue Beret-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-09-2014, 11:40 AM
#28
1976 31' Sovereign
Oswego
A 10 amp or larger blade fuse does same thing as plastic coated fuse I pur. Bare wire is a no no for any reason. Safety first no matter what AS general mgr. said to do.....
07-09-2014, 11:48 AM
#29
Princeton
, New Jersey
Not sure where the idea of turning on the parking lights came from but I must say as far as disrespect for your fellow campers goes it is one step short of dumping your sewage on the ground.
It might have a place on Time Square but not in the woods.
2004 Excursion 4x4
07-09-2014, 11:59 AM
#30
1978 25' Tradewind
Metro Phoenix
I'm actually planning to build a plug-in remote running light controller. I've got a cheap car alarm setup and a "vehicle end" socket. I'll probably end up putting them together in a plastic peanut jar so that the trailer cord just plugs in. Then when you go off in the woods to powder your nose or something, you just push the remote button to momentarily turn on the lights so you can find your way back.
07-09-2014, 12:16 PM
#31
2013 30' Classic
Greenwood
, Mississippi
It looks cool like rope lights or awning lights.
It is unplugged at bedtime- 9-10 PM-
I want blue rope lights to go around the bottom of the trailer.
TAC #MS-10
Airforums #70955
07-09-2014, 12:18 PM
#32
2013 30' Classic
Greenwood
, Mississippi
Safety?
What is unsafe?
The wire has insulation on it.
It is a 12 volt circuit- not much risk of electrocution-
I've seen a guy do it with a wire hot dog/marshmallow roasting stick-
TAC #MS-10
Airforums #70955
07-09-2014, 12:38 PM
#33
Princeton
, New Jersey
[QUOTE=m.hony;1480244]Safety?
What is unsafe?
/QUOTE]
The rule of electrical safety is never have an unprotected circuit.
While it is unlikely, because of pin configuration, if you were to connect battery to ground that wire would melt in your hands before you could drop it. Someone may see you do this and make the wrong connection, but then I assume you have insurance.
2004 Excursion 4x4
07-09-2014, 04:13 PM
#34
W
, New England
Here are the components I used. 12g wire with fuse holder - can take up to 30a blade fuse - a 10a fuse and a 7-pin cap to connect to the trailer's umbilical. The fused wire is connected at the 11 and 1 o'clock positions. Haven't tried it yet but am assuming this will be pretty safe with the fuse inline.
07-09-2014, 04:25 PM
#35
1976 31' Sovereign
Oswego
lights
Leaving scare light on is a lot more abrasive than running lights, I also turn them off at 10 pm or before as it depends how close other campers are. Common courtesy does wonders. But some people want to grouch about every thing.
07-10-2014, 06:14 PM
#36
W
, New England
I love quoting myself :-)
Just tried my contraption. Perfect! No sparks, no shock. Easy peasey!
07-10-2014, 06:53 PM
#37
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
07-12-2014, 04:55 AM
#38
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
07-12-2014, 06:41 AM
#39
Oswego
Not when you build a stainless steel "lampshade" for them.
-Rich-
07-12-2014, 07:54 AM
#40
Huntington
, West Virginia
Originally Posted by SilverGate
very cool
