Old 08-23-2014, 05:41 AM   #113
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by wahoonc View Post
I have a couple of SOB's They are wired the same way, and the jumper works the same.
Aaron
The first step is admitting it :-)
Just kidding - that was obligatory given your emoticon ;-)
Thanks for the answer! Glen will be thrilled and he could really use a simple pick me up this week!
Thanks!!
Old 08-23-2014, 11:31 PM   #114
MYater's Avatar
1948 22' Liner
Roy , Utah
Send a message via AIM to MYater Send a message via Yahoo to MYater Send a message via Skype™ to MYater
Originally Posted by SteveSueMac View Post
But isn't it universal? Aren't the 11 o'clock and 1 o'clock positions 12v and Clearance lights on every 7-pin cable?
Yes there is an industry standard for four, six, and seven pin RV plugs. You never know what somebody else has done with their trailer and vehicle however!
"Some things you can tap. Some things you can hit. Know which one is which!"
1948 Airstream Liner 22'
MYater is offline   Reply With Quote
Old 08-24-2014, 04:56 AM   #115
W , New England
Thanks. It worked on his trailer and he couldn't have been happier. I couldn't have been happier that such a simple thing could give someone such joy. Life is funny sometimes :-)
Thanks for the info. Now off to Walmart to get the materials to make a replacement for myself :-)
Old 09-03-2014, 07:51 PM   #116
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The remote running light flasher I referred to earlier was completed this past weekend. It consists of a vehicle-end 7-pin socket, a cheap car alarm brain off eBay, and a Costco plastic nut jar (the $9.95 size). Connect the hot, ground, and parking light flash wires to the socket, and you're in business.
I just slip the connector onto the trailer pigtail when I'm parked, and clip a remote onto each of the trailer key rings.
I'll snap a photo this weekend if anybody's interested.
No more guessing where the trailer is in the dark!
Old 09-03-2014, 08:39 PM   #117
W , New England
TOTALLY interested in pics, schematics, parts lists, etc! :-)
I'm going to make one for my father in law's SOB
Old 09-03-2014, 10:59 PM   #118
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
Turning on Running lights while camping
I would also be interested in pic and part lists etc
Tks
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 09-04-2014, 09:47 AM   #119
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I am only offended by the middle running light, never the outer two, and then only between 7:00 and 8:15 on weeknights... So, can someone please modify the schematic to turn off the middle running light between 7:00 and 8:15 on weeknights? Thanks!
-Red... and don't even get me started on blue citronella rope running lights...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 09-04-2014, 03:19 PM   #120
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am cool with the amber lights, but the red lights in the campground simply ENRAGE me...
Old 09-04-2014, 04:07 PM   #121
richw46's Avatar
Lexington , Kentucky
I've never had any problems finding my way back anywhere, but maybe that's just me. All I need is a flashlight. But if I was worried, I'd just take my cell phone with GPS and use the Maps feature to find my way back. I've even used the car GPS on a boat when I went fishing with someone who didn't have a GPS (It doesn't show islands so you can't go zipping across the lake in the fog. You can find your way back to the dock/camp, however.)
As far as the trailer lights go, I prefer the darkness but they don't keep me awake. I wouldn't do it on my trailer unless I was just checking bulbs. My trusty Coleman Dual Fuel lantern is plenty of light for this old Boy Scout.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-04-2014, 04:11 PM   #122
mefly2's Avatar
2015 25' FB Eddie Bauer
You can use a car flasher unit with two connectors and plug it directly in, not exactly a strobe but you still get the flashing effect. I suspect the cheaper and lighter the flasher unit the faster they will flash...
Aaron
Unless you have LED running lights ... then an LED specific flasher is needed due to the difference in current draw ...
Old 09-04-2014, 04:15 PM   #123
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
A flasher marked "heavy duty" will flash and flash consistently regardless of load.
Old 09-06-2014, 10:28 AM   #124
drboyd's Avatar
1978 25' Tradewind
OK, I used an Audiovox AA-925 alarm, but I'm sure there's a zillion that will work just the same. Check on the alarm's installation instructions, and as long as it has one "12+" lead, one "Ground" lead, and one "Parking light" lead, you're good to go.
The alarm instructions will tell you the color codes for the leads. The 12+ is usually red and the ground lead is usually black.
The ground wire goes to the #1 pin on your socket, the 12+ wire goes to the #4 pin and the "taillight " wire goes to the #3 pin.
Screw the lid back on the jar, and you're in business!
Note: I'm actually going to paint the jar, as soon as I decide on a color. Any suggestions?
ID:	220985   Click image for larger version
Old 09-06-2014, 07:09 PM   #125
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, paint it silver from the inside; That's how we painted Lexan RC car bodies.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-11-2014, 12:29 PM   #126
MYater's Avatar
1948 22' Liner
Roy , Utah
I'm thinking how funny it would be to have a speaker attached somewhere so you can chirp the trailer and make the lights flash as though it were locked.
I really do like the approach using the jar, and I agree with ROBERTSUNRUS to paint the inside if the jar. My wife has done some craft things and painting the inside always looks better, and you can't get too much paint and make it look bad.
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
Trailer running lights while camping henw Lights - Interior & Exterior 21 05-07-2008 11:55 AM
Turning on the lights 26.982 amu Electrical - Systems, Generators, Batteries & Solar 6 03-27-2006 05:42 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
