Old 07-20-2014, 09:32 PM   #57
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
From a distance, they kind of look like fireflies through the woods.....
arktos55343 is offline   Reply With Quote
Old 07-21-2014, 07:18 AM   #58
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by Smartstream View Post
I find it interesting about people complaining about lights at 10 or 11 o'clock at night.
I don't speak for the others but my comment of it being "disrespect for your fellow campers" relates to those that leave lights on All Night.
The 40 ft. diesel pusher that is locked up and lite up on all sides like the state prison is over the top. I actually feel sorry for those that are that insecure of their surroundings and question why they are camping at all.
2004 Excursion 4x4
Old 07-21-2014, 09:03 AM   #59
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Turning on Running lights while camping
I find it interesting how anymore every action by one is an affront to someone else.
Sorry, we have become a nation of bitter pansies.
While I am not set up to run my running lights at night, I can hardly imagine that such an action would be "intrusive" or disrespectful.
Pardon me, but if your window coverings are so poor that running lights are a distraction and a hinderance for sleep, then it is likely that your "inconsiderate" neighbors find your nakedness visible from your barely covered windows a distraction also.
Old 07-21-2014, 09:10 AM   #60
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I have not once had anyone in any campground express that they were offended by my running lights on...
They are not nearly as bright as the scare light and don't attract bugs, either.
Sure makes it easy to find the camper- look for the UFO-
It is so much easier to put a jumper wire in the umbilical plug than to string lights up in the trees or across the awning or run rope lights.
I can't help it that I was intrigued (not at all offended) when I first saw someone do this in a campground and I wanted to do it, too- so I did-
Coolness factor? Well, yeah.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-21-2014, 09:15 AM   #61
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
My husband made a jumper cable for the running lights. He used flattened rivets on the ends.They are far less intrusive than most lights in a campground. We have never left them on past about 10 pm.
I happen to like them.
I made window darkening shades for the bedroom because so many campgrounds have security lights and people leave other lights on all night.
Name:	jumper (800x600).jpg
ID:	217003   Click image for larger version
Name:	nightlights (1024x768).jpg
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 07-21-2014, 09:22 AM   #62
m.hony's Avatar
2013 30' Classic
Originally Posted by HowieE View Post
Not sure where the idea of turning on the parking lights came from but I must say as far as disrespect for your fellow campers goes it is one step short of dumping your sewage on the ground.
It might have a place on Time Square but not in the woods.
I totally disagree.
TAC #MS-10
Airforums #70955
Old 07-22-2014, 12:16 PM   #63
Skater's Avatar
1995 30' Excella
Bowie , Maryland
It's a great way to illuminate the campsite without overdoing it, I've found. If I don't have the awning lights out, the only light we have outside at all is our step light (we don't have an overdoor or scare light like most Airstreams). It's just bright enough with the running lights on that we don't walk into the picnic table or the camper itself when it's very dark. I'm glad I wired up the switch inside to turn ours on; we use it frequently.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-22-2014, 08:57 PM   #64
camper collector
Americus , Georgia
Smile Question about trailer 7 blade plug
Originally Posted by Inland RV Center, In View Post
Easy to do. You can make your own, by using a jumper wire between the charge line and the clearance light circuit terminals.
If you take the cover off the connector, those two wires would be the large blue wire, and the green wire.
Andy:
I just replaced my old metal 7 blade RV trailer plug for the newer Black plastic
7 Blade plug on the trailer.The old plug was corroded and the lights were not working.When I took it apart I noticed the yellow wire was taped up and not being used.So I wired the new plug with the color code on the new plug all left the yellow as it was in the old plug.All the running lights,turn signals work now. But I noticed the yellow wire now is HOT and it was not before and now I don't have brakes as I did before.Dis I wire it wrong in some place different to cause this?:
camper is offline   Reply With Quote
Old 07-26-2014, 08:57 AM   #65
Silver Spud
BillB44's Avatar
2010 23' FB Flying Cloud
Sagle , Idaho
Sorry, I just don't get the need to light up the woods with running lights past 9 or 10PM. Quiet time should also be dark time. Stars, campfires, flashlights ought to be plenty. The whole idea is to get out of the city and closer to nature, right?
The Silver Spud
BillB44 is offline   Reply With Quote
Old 07-26-2014, 12:06 PM   #66
m.hony's Avatar
2013 30' Classic
It isn't any brighter than all those other light sources you mentioned. It isn't as bright as a scare light or rope lights or tiki torches. It ain't about need. It's about fun. I have still never heard anyone say they were offended by my running lights.
TAC #MS-10
Airforums #70955
Old 07-26-2014, 12:13 PM   #67
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Fwiw, I haven't seen anyone post to this thread that says they burn their lights past ten, but even if they did I doubt it could bug me.
Sometimes the smallest actions become a huge points of contention.
Old 07-26-2014, 12:32 PM   #68
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Maybe?
I live in the middle of nature and camp to get away from the workload at home and work. Running lights on a camper are pretty innocuous compared to a lot of other things I see and hear in campgrounds.
Aaron
WBCCI #XXXX AIR #2495
Old 07-26-2014, 12:45 PM   #69
Colorado Springs , Colorado
To someone whose hobby is astronomy lights are a form of pollution. The ISS (International Space Station) is only visible naked-eye near dawn or near dusk.
minke is offline   Reply With Quote
Old 07-26-2014, 01:01 PM   #70
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It seems to me that a person who went camping for the benefit of astronomy would probably want to camp in a place conductive to that end, and not insist that the 99% who are camping for other reasons bend to their expectations.
Perhaps there are campgrounds dedicated exclusively for star gazing?
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
Trailer running lights while camping henw Lights - Interior & Exterior 21 05-07-2008 11:55 AM
Turning on the lights 26.982 amu Electrical - Systems, Generators, Batteries & Solar 6 03-27-2006 05:42 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
