Old 07-12-2014, 10:47 AM   #43
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Originally Posted by SteveSueMac View Post
I love quoting myself :-)
Hi from AZ. . . at least you're honest regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 07-12-2014, 11:46 AM   #44
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Not nearly as bright as the scare light and doesn't attract bugs...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-12-2014, 01:09 PM   #45
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
I used to stick a wire in the hot side and then to the clearance lights. It took me awhile but I eventually remembered which socket to plug in. Then I got an extra truck end and fastend that under the propane tanks and wired from the hot to the clearance lights. Just plug it in, I tried the brake lights but too hot,
I got new lenses from NAPA for all the rear lights... under $30 bucks for 6--- the back up lights were most expensive.
Got the flag pole up also. Heading out tomorrow on our trip west! Wanderlust strikes!
Jim Lee is offline   Reply With Quote
Old 07-12-2014, 01:53 PM   #46
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Running lights on.
Hi, in other threads, I have pictures of the two control boxes that I made for turning on my running lights and brake/hazard lights. One is fairly simple and only flashes the running lights. [this one was built for emergency use] The other one has many more modes of operation. [this one was built for fun at rallies] They won't be used at regular camp grounds or state parks Etc. I originally built the first one with a 10 Amp fuse and it worked fine with my trailer that has LED tail lights. But after trying it on someone else's trailer with several incandescent light bulbs, we changed the fuse to a 20 Amp.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 07-12-2014, 03:22 PM   #47
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have done this for years with a variety of RV's. It started when my kids were younger so it was easier for them to find our popup in the late evening when they were walking back from the bath house. I used to just use a jumper wire. Now I will build a fancy pants version with the plug cover, switch and fuse. Now it would probably help me find my unit in the dark.
We were staying at a large park in Myrtle Beach, SC when someone had an emergency. Happened to be an Airstream and they had the lights flashing so the EMT crew as well as the campground folks knew right where to head.
I also like the idea of having it available to use in an emergency roadside, though I hope I never have to abandoned any of my trailers on the roadside. So far in 30+ years of dragging trailers around I have never had to... knock on wood.
Aaron
WBCCI #XXXX AIR #2495
Old 07-20-2014, 06:36 PM   #48
2010 23' FB Flying Cloud
Sagle , Also Southern Cal. when the snow flies up north.
I'm with Howie
Originally Posted by HowieE View Post
Not sure where the idea of turning on the parking lights came from but I must say as far as disrespect for your fellow campers goes it is one step short of dumping your sewage on the ground.
It might have a place on Time Square but not in the woods.
This could probably be a whole side thread in itself but, anyway, the practice of leaving exterior lights on in a serene, natural setting seems kind of rude and self-serving. Maybe if you're in an urban, private CG or with a group at cocktail hour, etc. it's less obnoxious. The thing is, many folks camp to savor the outdoors, darkness and all. I've camped in spots where big motor homes are festooned with rope lights and neon signs. Yes, they eventually turn them off at 9 or 10, but that doesn't help if you just want to eat outside or sit and ponder the stars. Most Airstreamers we've met are of like mind and extremely considerate. Maybe I'm turning into a grumpy old man---as I re-read this, it sounds like it--but I'm really not; I like to party, drink and enjoy life too. But I would never do any of that if it came close to disturbing a neighbor camper. Leaving on all the running lights just to look cool, seems pretty shortsighted.
BillB is offline   Reply With Quote
Old 07-20-2014, 06:44 PM   #49
m.hony's Avatar
2013 30' Classic
No more rude or obnoxious than rope lights, awning lights, scare lights, or street lights...
TAC #MS-10
Airforums #70955
Old 07-20-2014, 06:48 PM   #50
m.hony's Avatar
2013 30' Classic
There is definitely a coolness quotient to having the running lights on. They are a lot less bright than the scare light and attract 0 bugs. I generally only turn them on while sitting around the fire socializing. When I go in, they're turned off.
TAC #MS-10
Airforums #70955
Old 07-20-2014, 07:20 PM   #51
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Let's face it, regardless of the serenity of the darkness and forest setting (which I am all for, btw), whenever you get a bunch of people together with cocktails...there will be a lot of raucous noise that often lasts well into the night. So, why not add a little festive lighting to go with it? I would never keep them on all night...or even late... but it sure helps find your rig when you are returning from brushing your teeth..... hehehe.
Oh, as I was rewiring my AS, I hooked up the running lights and the 'party' light to separate switches by the door....so I can be as discreet as necessary.
arktos55343 is offline   Reply With Quote
Old 07-20-2014, 07:41 PM   #52
Salem , Oregon
Images: 18
Hi, I like your belt line light; Maybe you could show us how you installed it/them.
2005 Safari 25-B
Old 07-20-2014, 07:43 PM   #53
2016 28' Pendleton
Hi from AZ. . . what he said. . .when it's my turn to host happy hour, I do the lights. when we break up, they go off. Several SOB people have asked if that's an exclusive feature of an Airstream Regards, Craig
WBCCI 2851,4CU
Old 07-20-2014, 07:45 PM   #54
m.hony's Avatar
2013 30' Classic
I've seen sob's turn on the running lights, too.
I have also seen sob's with strips of led lights all along the bottom.
TAC #MS-10
Airforums #70955
Old 07-20-2014, 08:13 PM   #55
1972 25' Tradewind
Hopkins , Minnesota
Beltline LED strip
It was all an experiment... I have been working on the electrical...and changing all the lighting to LED...inside and out. I was hunting around on Amazon, and ran across lengths of LED strip lights in various colors and 16 foot lengths...which just happened to be the exact width of my belt line...and they were only about $12 each. So, since I was about to paint my belt line the original blue color, I figured "why not?"....just for fun.
I ordered a couple roles of the LED strips. As I said, they come in 16 foot lengths, and are waterproof with 3M double sided tape. They can be cut to length at every 3rd LED.
I drilled a small hole through my belt line where it meets under the rear window. I then fit a small tube with a flange end into the hole (with Tempro to seal), through which I threaded the strip light lead wires. I then peeled the 3M tape off the back of the strip and began applying it to the belt line. It just so happened that where I met the Trade Wind plate on the side of the trailer, was exactly where I could make a cut in the strip. It fit perfectly. I did the same on the other side of the trailer.
When I had the strips stuck, I joined the wires inside under the rear window... attached one set of wires to a ground point on one of the support 'studs' beneath the window, where my LED brake/turn/reverse lights are also grounded....and then ran the power lead to a switch by the door...and then to the 7-pin running light circuit.
It's a fun project....but I have to admit...there are issues with these cheap LED strips. They come from China....and the quality is not great. I've had issues with LEDs burning out too quickly. I will either find another supplier...or scrap the idea and paint the belt line blue....as god intended....LOL.
Old 07-20-2014, 09:18 PM   #56
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I find it interesting about people complaining about lights at 10 or 11 o'clock at night. Where we are in Alaska it's day light until nearly midnight. I guess they would have real problems getting to sleep. By the way I've always thought the clearance lights on was a neat idea.
Cheers, Dan
~ Margaret Thatcher ~
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
Trailer running lights while camping henw Lights - Interior & Exterior 21 05-07-2008 11:55 AM
Turning on the lights 26.982 amu Electrical - Systems, Generators, Batteries & Solar 6 03-27-2006 05:42 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
