07-09-2014, 11:48 AM
#29
Princeton
, New Jersey
Not sure where the idea of turning on the parking lights came from but I must say as far as disrespect for your fellow campers goes it is one step short of dumping your sewage on the ground.
It might have a place on Time Square but not in the woods.
2004 Excursion 4x4
07-09-2014, 11:59 AM
#30
1978 25' Tradewind
Metro Phoenix
I'm actually planning to build a plug-in remote running light controller. I've got a cheap car alarm setup and a "vehicle end" socket. I'll probably end up putting them together in a plastic peanut jar so that the trailer cord just plugs in. Then when you go off in the woods to powder your nose or something, you just push the remote button to momentarily turn on the lights so you can find your way back.
07-09-2014, 12:16 PM
#31
2013 30' Classic
Greenwood
, Mississippi
It looks cool like rope lights or awning lights.
It is unplugged at bedtime- 9-10 PM-
I want blue rope lights to go around the bottom of the trailer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
07-09-2014, 12:18 PM
#32
2013 30' Classic
Greenwood
, Mississippi
Originally Posted by featherbedder
A 10 amp or larger blade fuse does same thing as plastic coated fuse I pur. Bare wire is a no no for any reason. Safety first no matter what AS general mgr. said to do.....
Safety?
What is unsafe?
The wire has insulation on it.
It is a 12 volt circuit- not much risk of electrocution-
I've seen a guy do it with a wire hot dog/marshmallow roasting stick-
TAC #MS-10
Airforums #70955
07-09-2014, 12:38 PM
#33
Princeton
, New Jersey
[QUOTE=m.hony;1480244]Safety?
What is unsafe?
/QUOTE]
The rule of electrical safety is never have an unprotected circuit.
While it is unlikely, because of pin configuration, if you were to connect battery to ground that wire would melt in your hands before you could drop it. Someone may see you do this and make the wrong connection, but then I assume you have insurance.
2004 Excursion 4x4
07-09-2014, 04:13 PM
#34
2012 27' Flying Cloud
W
, New England
Here are the components I used. 12g wire with fuse holder - can take up to 30a blade fuse - a 10a fuse and a 7-pin cap to connect to the trailer's umbilical. The fused wire is connected at the 11 and 1 o'clock positions. Haven't tried it yet but am assuming this will be pretty safe with the fuse inline.
07-09-2014, 04:25 PM
#35
1976 31' Sovereign
Oswego
lights
Leaving scare light on is a lot more abrasive than running lights, I also turn them off at 10 pm or before as it depends how close other campers are. Common courtesy does wonders. But some people want to grouch about every thing.
07-10-2014, 06:14 PM
#36
W
, New England
I love quoting myself :-)
Just tried my contraption. Perfect! No sparks, no shock. Easy peasey!
07-10-2014, 06:53 PM
#37
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
07-12-2014, 04:55 AM
#38
2013 30' Classic
Greenwood
, Mississippi
TAC #MS-10
Airforums #70955
07-12-2014, 06:41 AM
#39
Oswego
Not when you build a stainless steel "lampshade" for them.
-Rich-
07-12-2014, 07:54 AM
#40
Huntington
, West Virginia
Originally Posted by SilverGate
very cool
07-12-2014, 08:19 AM
#41
Huntington
, West Virginia
If your camp sites are separated by trees, then I can't see that it would cause that much of a disturbance. Probably best to avoid camping close to people who have problems with lights at night- win-win for both parties.
07-12-2014, 10:41 AM
#42
2013 30' Classic
Greenwood
, Mississippi
I've seen lots of other campers in the campground with the running lights on. That's where I got the idea. It didn't disturb me. I thought it was cool. I'm like, "Hey, how'd you do that?"
TAC #MS-10
Airforums #70955
