Old 01-06-2015, 08:03 PM   #127
ODSCS's Avatar
2013 22' FB Sport
Seal Rock , Oregon
Images: 8
I posted on another topic about 12 lines down this list on "Emergency lights on your A/S trailer with no tow vehicle" a unit that I constructed. Photos, parts and wiring are shown. The unusual aspect was the LED running lights required a special LED rated flasher as the newer A/S trailers have. Just completed a 2500 mile journey and now have covers to place over the tail lights to reduce the annoying brightness from them.
ODSCS is offline   Reply With Quote
Old 01-06-2015, 08:12 PM   #128
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I see this turn on the running lights device as an emergency device if I have to leave the trailer beside the road after dark. The trailer batteries could power those LEDs for a week, if necessary. I have several "small" pocket sized 200 candle power flashlights to walk around with in the dark. A flasher model for the brake lights and steady "on" for the running lights would perhaps get more attention.
Old 06-19-2015, 01:07 PM   #129
albert's Avatar
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Tulum , Mexico
Send a message via AIM to albert Send a message via Yahoo to albert
Show finished piece
Originally Posted by SteveSueMac View Post
I love quoting myself :-)
Just tried my contraption. Perfect! No sparks, no shock. Easy peasey!
Can you show a pic of the finished piece that you wired up?
albert is offline   Reply With Quote
Old 06-19-2015, 01:23 PM   #130
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Will do when I get back to the trailer Albert.
SteveSueMac is online now   Reply With Quote
Old 06-20-2015, 02:04 PM   #131
Loafy the Wonder-Sled
Tumbleweed61's Avatar
1986 25' Sovereign
Mercury , Nevada
Thumbs up
I just want to say thank you for this thread, because it inspired me to attempt to power up the running lights, whereupon I was able to identify the fact that the "Charge Line" circuit breaker (power from the TV to the AS batteries) is bad. (We have not gone on a long enough trip yet to have realized that this was a problem.)
One repair and a couple of jumpers later, and I now am able to turn on the running lights steady or flashing.
Thanks again.
"The sting of having paid too much remains long after the veneer of newness has worn away."
'86 Sovereign 25'. Somewhere near Mercury, NV
Tumbleweed61 is offline   Reply With Quote
Old 06-20-2015, 02:51 PM   #132
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
This is a great thread I just put a 10 amp spade fuse in and boom lights. I am going to pick up a flasher as well.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 06-20-2015, 03:39 PM   #133
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
This is my rally light doohickey. It is hot wired with a 10 amp fuse for lights continuously on. Pull the end cap, swap one wire and the flasher is in line. Total cost $1. Plug was on the discount shelf at West Marine as an open box/defective return. Rest of the parts were from my junk box in the garage. 💡
MICHAEL
Old 06-20-2015, 03:56 PM   #134
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by AWCHIEF View Post
This is my rally light doohickey. It is hot wired with a 10 amp fuse for lights continuously on. Pull the end cap, swap one wire and the flasher is in line. Total cost $1. Plug was on the discount shelf at West Marine as an open box/defective return. Rest of the parts were from my junk box in the garage. ��
Hi, My original light control box was made with a 10 amp fuse, but when we plugged it into a Classic with all incandescent bulbs, the fuse blew. So I changed it to a 20 amp fuse.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-20-2015, 04:11 PM   #135
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That's all I do.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-20-2015, 06:36 PM   #136
AWCHIEF's Avatar
Images: 33
Glad you posted that. I went out to double check what fuse was in my doohickey. Low and behold sometime in the last couple of years I put in a 15 amp fuse. Don't know why or when but I suppose I had a good reason (or not) at the time.
MICHAEL
Old 06-24-2015, 07:32 PM   #137
W , New England
Hi - I think AWCHIEF's doohickey looks WAY better than mine. I could have just plugged the 10 amp blade fuse in to the 7-pin connector but I used a male 7-pin head with the 11:00 and 1:00 positions wired to a fuse receptacle. This way, instead of the (slight) chance of accidentally shocking myself, I can just slip the contraption on the trailer's connector and I'm good to go. If the fuse ever blows (never has so far) the receptacle is exposed so it's a quick swap of fuse and back in business.
But Chief's is really much cooler :-)
Name:	ImageUploadedByAirstream Forums1435195950.021916.jpg
Old 06-24-2015, 08:03 PM   #138
AWCHIEF's Avatar
Images: 33
I have been know to over think very simple projects. Thankfully this one was completed without having to take out another bank loan.
MICHAEL
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Turning on TV lights blows fuse when trailer connected shinybean Lights - Interior & Exterior 4 08-16-2009 09:48 PM
Trailer running lights while camping henw Lights - Interior & Exterior 21 05-07-2008 11:55 AM
Turning on the lights 26.982 amu Electrical - Systems, Generators, Batteries & Solar 6 03-27-2006 05:42 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
