12-23-2009, 01:59 PM
1972 23' Safari
Houston
Turning on Running lights while camping
So at the Blanco Rally a few of the Trailers had plug adapters that turned on all of the running and brake lights while we were camping. Made a nice addition and looked cool. I was told that all that's needed is a connector (TV side with the pins connected (soldered etc.). So can those of you in the know tell me which connector to buy and what pins to wire together, a general "how to" build or buy. Thanks
12-23-2009, 02:04 PM
Send a PM to Toddster. He made one that came to me with my Safari.
Rich the Viking
12-23-2009, 02:07 PM
Corona
Easy to do. You can make your own, by using a jumper wire between the charge line and the clearance light circuit terminals.
If you take the cover off the connector, those two wires would be the large blue wire, and the green wire.
12-23-2009, 02:16 PM
Princeton
, New Jersey
Just connecting the terminals at position 1 and 11 o clock on your umbilical cord will do it.
As noted above a 2 prong car flasher will fit directly into these terminals and cause the trailer lights to blink, not the brake lights. If you solider 2 male spade connectors to a short piece of wire and insert that into these terminals the trailer light, not the brake lights will stay on.
Please note if your trailer has filament bulbs make sure you use at least a #12 wire because of the current, if you make your own.
2004 Excursion 4x4
12-23-2009, 02:28 PM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
use an automotive in-line fuse holder....otherwise, there won't be any fuse protection on the circuit.
(under "normal" circumstances, the lights are fuse-protected by the tow vehicles fuses.).
I just crimped on a spade connector to each lead on the fuse holder, and stick one in @ 11, the other @1.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
12-23-2009, 03:17 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
PLEASE DON'T---- The person parked behind me had his on all night and made it difficult to sleep. I had to hang towels over the windows to help reduce the flashing.
Rember your fellow campers; "and do unto others"
12-23-2009, 03:37 PM
1972 29' Ambassador
Harrah
, Oklahoma
Why didn't you ask him to close his window curtains.. oh wait, you were talking about flashing lights.
My Brain Project and Tech Notes
12-23-2009, 03:38 PM
Now if you had one of these you could have had light wars all night, and done to others as they be doin' to you.
12-23-2009, 03:44 PM
1958 22' Flying Cloud
1974 Argosy 28
1978 Argosy 24
Travelers Rest
, South Carolina
LIghts at night
If you must turn on the lights PLEASE be considernate and turn them off by 8 or 9 PM. We have added room darking curtains and still fellow RV's insist on lights everywhere. How will you see the stars? Or sleep? We don't have any outside lights where we live and just the glow from the nearest town 13 miles away is distracting when you walk outside at night.
Richard & Linda
Tumbleweed ('78 Argosy)
Travelers Rest, SC
12-23-2009, 04:12 PM
2003 22' International CCD
Kiln
, Mississippi
One additional benefit from the flashing light setup is if you have to leave your trailer on the side of the road while the TV is disconnected. For instance, if the TV is not operating and the tow company can only tow the TV then the flashers will work off the trailer battery until you can return. Another example is if there is a need for emergency help in a campground and you call for assistance - your trailer can be the one with the flashing lights to identify yourself easily to the first responders.
I setup one that uses a 7-pin connector for a TV (female connector) on a 4" PVC endcap and all the electronics in a 6 inch piece of PVC pipe with another cap on the end. Works good and allows you to just "plug in" when you set up at the camp site - it has an on/off switch. Another benifit of using a female plug in is you protect your RV plug from damage.
PM if you want pictures. BTW - I set it up with a three way switch (On, Off, Flash) I got great advice from many people here on how to do all this - I can provide my wire diagram if you want.
Mike
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
12-23-2009, 04:26 PM
slightly off-topic
I made black-out shades for my Safari, for using it at Burningman where
everything is 24/7. After one outing I decided to forego curtains altogether.
There will always be some inconsiderate people out there, and this really helps with both light and noise, and I don't have to rely on the good character of my neighbors to get a good nights sleep
12-23-2009, 04:56 PM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
For those who don't feel up to building your own:
Plug-n-Light 5th Wheel Accessories
Have nothing to do with this outfit and have never used this product. Do know it was in Trailer Life. Unfortunately this unit just allows for steady light - it does not have the flasher option.
12-24-2009, 09:30 PM
2006 19' Safari SE
Tucson
Here's another product... we have one. It's great and allows us to have the running lights and tail lights on (constant)... or to have the running lights on (constant) with flashing tail lights... http://www.westhaverassociates.com/flashcube/
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
12-24-2009, 09:41 PM
2007 23' Safari SE
San Diego
12-24-2009, 09:53 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
That's exactly how i have been doing it for years. The 10 amp fuse stays in place and provides a fused connection. Since I have replaced all of Lucy's clearance lights with LED bulbs, it doesn't matter if I leave them on all night as there is no heat build up.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-24-2009, 10:56 PM
1978 31' Excella 500
Venice
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
12-25-2009, 10:03 AM
Anywhere &
, Everywhere
If anyone was thinking about ordering a FlashCube forget it - the company is dead. Just tried to place order myself. You have to go to the Home Page to find that they are out of business. Bummer.
12-25-2009, 10:30 AM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
I have a flasher for each trailer which I can plug into the pigtail. Sure, they can be fun when parked. But, I carry them to be used like an emergency flasher. I don't make a habit of towing at night, but, if I am, and have trouble and have to leave the trailer along side of the road to go for help or something else, I can leave the running lights on the trailer flashing while I am gone.
I have never had to do that, but if I have to sometime, I will feel much better about leaving the trailer in the dark.
Merry Christmas
07-02-2014, 05:58 PM
1975 25' Tradewind
Sherbrooke
, Quebec
Running lights always on... But I don't want them to be.
Lets see if I can rekindle this thread...
I came back from a short outing last week-end and when I parked my 1975 Land Yacht 25 ft DB, I unplugged it from the truck and the running lights stayed on.
Before said trip, when I unplugged de AS, the lights went off. The only way to turn them on was to plug the trailer to the truck and then turn the truck lights on.
I want it to go back the old way.
I figured out that the problem is with the umbilical cord. When I unplug it from the trailer, the lights shut off. I am therefore assuming that I need to check for a short between two wires in the cord. Or buy a new one. This one is in OK shape but could be better (as this problem of mine seem to indicate).
Any other insights?
Thank you!
Ghislain
