Old 01-04-2009, 11:37 AM   #1
1967 20' Globetrotter
Houston , Texas
Turn Signal Problem
I have a problem with the left turn signal on my globetrotter. The rear lights both work when the TV's headlights are on and the right light blinks when the turn signal is on; however, the left light doesn't function as a turn signal. Does anyone have a suggestion on the cause and a possible remedy?
tphillips is offline   Reply With Quote
Old 01-04-2009, 11:43 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Bulb,Taillight side can work but the brake light side may be blown.Do your brake lights work on trailer and tv[tow vehicle]?Turn signal on tv work? My chevy tv,has separate fuse for trailer turn signals.
easyride is offline   Reply With Quote
Old 01-04-2009, 12:11 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Take out the left bulb and use a voltmeter to see if the 12 volts are blinking on and off like they should. If not, disconnect the trailer connector and check for voltage at the plug on the tow vehicle. It looks like you have a good ground on the light, otherwise the running lights would not be working.
Old 01-04-2009, 03:58 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Happy New Year.
The taillights on my GT were continually causing problems until I finally gave in and replaced them.
The sockets and back plates are steel, the contacts for the bulbs are mounted on a piece of fiberboard pushed upward by a spring. The whole thing grounds to the body by the 4 small pop rivets. The usual problems were weak contacts and bad grounds.
Assuming you have voltage to the turn signal side of the bulb, the socket and contacts need to be clean and free of rust and corrosion. If not the turn signal circuit will use the running light circuit as the ground. This looks like a dim or out of sync flash when the running lights are off. Really bad and it won't work at all. Running lights can also ground through the brake filiments at times.
As the backing plates rusted it became harder and harder to keep a good ground through to the body. Drilling out and re-riveting would only work for a while.
If the sockets are good you might want to consider taking off the whole assembly for cleaning. Make sure the body is clean and put a new seal in the groove on the backing before riveting it back on.
Good luck, hope this helps,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-04-2009, 04:20 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I think Tom has the answer as a short term fix you can run solder a new ground wire to the bulb socket.
To test if ground is the problem you can run a jumper wire and touch it to the side of the bulb while it is in the socket.
Garry
Turn signal lens 76sovereign Lights - Interior & Exterior 15 01-29-2009 11:46 AM
Brake and Turn Signal Problems with Mercedes dougderocker Lights - Interior & Exterior 12 11-09-2008 02:29 PM
Weird turn signal problem, maybe TV related AxelBruijnis Lights - Interior & Exterior 25 09-17-2008 03:28 PM
Turn signal problem! Dale M Electrical - Systems, Generators, Batteries & Solar 6 06-22-2006 05:25 PM
turn signal problem Cruiser Electrical - Systems, Generators, Batteries & Solar 9 10-25-2004 06:27 PM
