Old 06-07-2014, 08:56 AM   #1
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Tripping source GFI
Recently my "tin can" has started tripping my house GFI. The GFI is on a separate 20 amp circuit with a GFI breaker in the main breaker box. The breaker in the box trips immediately upon plugging in. Where do you start on solving this one? Any help would be appreciated. Oh yes, it tripped a campground GFI last time out!
mhilley is offline   Reply With Quote
Old 06-07-2014, 09:40 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You have a short. Try turning off all of your trailer circuit breakers and systematically turning them on one at a time to try to isolate the problem circuit.
If the circuit trips with all trailer circuits off, the short is between the house outlet ant the circuit breaker box.
Old 06-07-2014, 09:44 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If you are able to isolate a particular circuit within your trailer, unplug all devices and systematically plug things back in till the problem device is isolated.
If unplugging everything on the suspect circuit does not stop the trip, then the fault is hard wired in and you are likely going to need the services of a good electrician.
Old 06-07-2014, 11:40 AM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Above reads;;
SHOULD READ;;
If the circuit trips with all trailer circuits off, the short is between the house outlet and the TRAILER circuit breaker box.
Old 06-07-2014, 03:12 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Before you start looking for more complicated reasons, check the fit between plug and socket. A loose fit can cause tripping because it increases the electrical resistance at the connection. I tripped a campground breaker because the socket at the pedestal was worn and my cord didn't plug in tightly.
A worn plug or socket would also help to explain why it's only now becoming a problem, if it wasn't as worn before.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-07-2014, 04:27 PM   #6
richinny's Avatar
2011 34' Classic
moisture in the exterior outlet and the one for the fridge are common culprits.
Ricky
new power supply now tripping GFI housebg Batteries, Univolts, Converters & Inverters 32 04-16-2009 01:15 PM
GFI tripping altamont Batteries, Univolts, Converters & Inverters 19 09-04-2008 11:22 AM
Dometic RM100 tripping GFI tschat Refrigerators 3 08-21-2006 09:01 PM
GFI breaker keeps tripping. Van Electrical - Systems, Generators, Batteries & Solar 10 08-06-2005 11:33 PM
GFI Tripping grizzy Electrical - Systems, Generators, Batteries & Solar 3 09-07-2004 06:17 PM
