Old 05-04-2008, 05:50 PM   #1
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Trailer running lights while camping
Does anyone remember which two contacts in the seven pin trailer umbilical cord you jump to turn on the trailer running lights?
Thanks, Tom
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 05-04-2008, 05:56 PM   #2
Thanks, Tom
The center pin (12 volts) and the green wire.
Take the plastic cover off and you will see all the colors.
The tail lights will also come on with the clearance lights.
Old 05-04-2008, 06:03 PM   #3
_
...which two contacts in the seven pin...
hi tom..
on mine (and yours) it's the top 2 connections (marker and battery) on either side of '12 oclock', i think...
with NO involvement of the center connector...
here is a post with links to threads that have PICTURES
http://www.airforums.com/forums/470129-post20.html
beside the party value...
this came in VERY handy when i needed a tow and the tow truck didn't have proper connections...
a simple fused wire can be used, but i like the flasher relay instead and it fits perfectly!
cheers
2air'
Old 05-04-2008, 06:16 PM   #4
Cyclist
henw's Avatar
Thanks so much. Just tested it with a fused wire and 1 + 7 does it. However, license plate light didn't come on. Is it suppose to light with the running lights, or, just when backing?
Tom
2007 28' Int CCD.
Two big screens
Centramatics.
Old 05-04-2008, 06:34 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Tom
It's supposed to light when the running lights are on.
Old 05-04-2008, 06:44 PM   #6
Cyclist
henw's Avatar
Thanks Terry, I think I may have inadvertently discovered a bad bulb.
Tom
2007 28' Int CCD.
Two big screens
Centramatics.
Old 05-04-2008, 07:40 PM   #7
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I have made up a truck-side trailer connector that allows me to plug in a lamp for my flags, and switches the clearance lights on. I just wired the battery lead in the plug to the light lead.
These two connections are side-by-side on the trailer side of the 7-way plug. One could just shove an ATC blade type fuse into the respective positions and light the running lights. They are the two connections seperated by the plastic ridge that positions the connector properly when plugging it into the truck side.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-04-2008, 08:02 PM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If you plug in an old style flaser unit in those two holes the lights will flash.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 05-04-2008, 08:05 PM   #9
Well Preserved
1993 21' Sovereign
If you do this, the part number for the flasher is #552.
Old 05-04-2008, 09:07 PM   #10
1975 27' Overlander
High River , Alberta
With ours, there's a handy switch inside the trailer that must have been installed by a previous owner. It's just below the front window, on the ledge behind the sofa.
AlbertF is offline   Reply With Quote
Old 05-05-2008, 05:04 AM   #11
Baltimore , Maryland
At Cherry blossom everyone was doing this lighting of trailers. It was a beautiful sight. Over to the side was a lonely 62 Overlander that could not due to no 12 volt system. He felt so left out... well now that Overlander has a fully functioning 12 volt system and the lights will blaze at the next rally. And they all lived happy ever after.....
Old 05-05-2008, 09:44 AM   #12
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
And then there are those of us that have the round NINE pin connector!
So I was just wondering if you just started plugging wire together and you put the flasher between the hot lead and your brakes, would the brake magnets get fried??
just wondering
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 05-05-2008, 09:52 AM   #13
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can take a plug and wire it with a rotory switch (make a PVC pipe housing). Then you need only plug it into the trailer socket and select which lights to light (you can add the flasheer inside too).
I don't believe the brake lights are parasitic on the magnet circuit-they have their own circuit, so lighting the brake lights shouldn't pulse the magnets.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-05-2008, 09:59 AM   #14
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
The ? is-- if 12V was applied to the brakes would the magnets fry? What voltage do the brakes operate on any way?
oops sorry for the hijack
What I'm getting at here is if you had a flasher in one hand and a beer in the other and started poking into the trailer connector what damage could occur?
www.popasmoke.com
YETI ( 65 Quart )
No running lights! Bing-Bing Lights - Interior & Exterior 5 08-01-2008 07:34 AM
Running lights Devoman Our Community 16 03-21-2006 08:45 AM
No Running Lights Craftsman Electrical - Systems, Generators, Batteries & Solar 5 09-12-2005 07:47 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Running Lights Joe Z Lights - Interior & Exterior 7 12-11-2003 08:48 PM
