Old 09-24-2014, 09:51 AM   #1
Norm excella's Avatar
1971 31' Excella 500
Many , Louisiana
Trailer plugged to tow vehicle
Without a battery hooked up in my airstream, what should I expect to have power from my truck when the 7 way plug is connected?
Norm
Norm excella is offline   Reply With Quote
Old 09-24-2014, 10:14 AM   #2
richw46's Avatar
Lexington , Kentucky
Since there is no battery in the box, I would expect that nothing in the trailer would have 12vdc power.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-24-2014, 10:44 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
running lights
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-24-2014, 11:01 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The exterior light are powered from the truck and have nothing to do with the trailer battery.
You should have all 12 volt functions in the trailer because the 12 volt feed from the truck goes to the common positive terminal in the distribution panel. That said do not attempt to turn on much more than one light at a time as the wire coming from the truck is too small to support a heavy current draw.
2004 Excursion 4x4
Old 09-24-2014, 11:38 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
...and it depends on the truck, too.
On my Dodge, the +12v charge line is always hot, whether the truck is running or off. This feeds the 12v circuits in the trailer, so everything should work.
I've done this purposefully to get a "boost" toward the end of a boondocking outing, when the trailer battery is getting weak, lights are dim....plug in to the truck, and "poof"--lights brighten up.
Just know, you're draining your tow vehicles battery when you do this.
Other makes/models don't leave the +12v hot, unless the vehicle is running.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-24-2014, 12:29 PM   #6
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
sorta related??? if I have a dead battery on the tv and fully charged batteries on the trailer can I plug the trailer into the tv and jump start the tv?
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 09-24-2014, 12:33 PM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You might get a little assistance for a weak battery that can barely turn the truck over, but if the truck battery is really dead, the charge line through the umbilical wouldn't have the capacity to help start the truck even if there's not an inline diode that prevents backfeeding to the truck.
You'd do better removing a battery from the trailer and hooking up to the truck with jumper cables.
David
Old 09-25-2014, 09:35 AM   #8
richw46's Avatar
Trailer breakaway brakes won't work if there's no charged battery connected; right? That would be a little dangerous.
I knew the exterior trailer lights would work, I thought he was asking about the interior 12v usage. To tell the truth, I'm surprised that anything would work on the inside with no battery in the circuit. I learned something today.
-Rich
Rich & Yvonne
2004 4Runner SE
Plugged or Un-plugged in the Driveway clancy_boy Winterizing, Storage, Carports & Covers 25 10-02-2017 01:14 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
'feedback' to T.V. when plugged into trailer. NJtoNC Towing, Tow Vehicles & Hitches 5 06-21-2010 09:12 AM
Question - Keeping Trailer Plugged In kamadeca Electrical - Systems, Generators, Batteries & Solar 5 05-08-2006 12:28 PM
