Old 04-10-2015, 07:16 PM   #1
I Bought it I Broke it...
clicknathan's Avatar
1976 31' Sovereign
Migratory , North America
Trailer Lights on a 76
I replaced the input on my 1976 Airstream, or rather my dear old dad did, a few months back, with a standard 7 pin female end. We then bought a standard 7 pin connector from Tractor Supply Co. (the kind with a male end on both ends of the cable), hooked it up to my 2006 Ford E350, and everything worked perfectly.
That cable somehow came out of the van a few days ago and was torn to shreds as it was dragged down the road.
So I couldn't find any of these cables in the town we're at (Tucson, go figure...)
So I'm going about building my own.
I have wired everything up as per the instructions with the following possible exceptions:
1. The center wire is labeled as "auxiliary". From other websites, I've read that this is used for backup lights. Either way, I plugged the yellow wire into the center cable.
2. I'm also assuming that + is the same as battery, or that the black wire is supposed to go into the "battery" connection.
I've even tried switching those two around, to no avail.
All I end up with is the brakes working perfectly (not brake lights, just the actual brakes), back left backup light on the trailer is ALWAYS on (while plugged in and the van turned on), and nothing else works at all.
I'm trying different combos but the possibilities are just about endless with 6 wires that aren't necessarily working...
Anyone ever experienced this? Any thoughts?
My family and I have been full-timing via various modes of travel since 2008. Going on two years in our '76 Sovereign.
clicknathan is offline   Reply With Quote
Old 04-10-2015, 07:21 PM   #2
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Trailer Wiring Diagrams | etrailer.com
This should help.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 04-10-2015, 07:44 PM   #3
1976 31' Sovereign
Yeah I've followed that too mnmhays. That's where I got that yellow is backup.
Currently have everything disconnected except white/ground, black/+ and blue/brakes and testing one at a time...
Old 04-10-2015, 07:46 PM   #4
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Yellow should be L Turn...nothing needs to go to the center pin...
Use the traditional diagram not the RV one.
Old 04-10-2015, 08:24 PM   #5
1976 31' Sovereign
Well we had required the airstream going into the plug (ie, the inputs on the outside of the airstream). The most puzzling thing is that the standard plug that was already wired which I purchased from Tractor Supply worked perfectly. And this one I had to build I wired exactly to spec.
More so, I discovered that it's the black wire / + that's keeping the back left light on constantly.
But even just wiring up say just the left turn signal wire, that still doesn't work. All I've got is brakes and it's getting dark so I'm giving up for tonight but wowzers how strange.
Old 04-10-2015, 10:48 PM   #6
2007 22' International CCD
Check grounds very carefully. Weird stuff can easily happen if ground is not right....
KE4GNK/AE
rmkrum is online now   Reply With Quote
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
