Originally Posted by Lumatic
As far as the tailights there are basically only 2 points where there are wire connections. The first is the umbilical plug at the front of the trailer. The second is where the wires enter the tailight.
A can of spray electronic cleaner may help.
Yep. Make sure you spray electrical cleaner both on the truck's electrical receptacle and on the pigtail connector on the airstream. Also you can stop by an rv repair place and they probably will have a dummy pigtail used to rest all of the electrical connections coming out of your truck. It plugs int the truck receptacle and has lights on it showing whether each connection is live and working.
Good luck!
