Old 07-13-2011, 05:09 PM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
My trailer came from the factory with lights very similar to these:
Taylorbrite(R)
The difference is that, with the exception of a galley light mounted on the bottom of a cabinet, they're slightly recessed into the ceiling so that they don't reduce headroom as much. I would imagine that the recessed ones are available from Airstream dealers.
Several internet retailers sell the surface mount ones for around $80 each.
I have one 30w fixture and six of the 16w fixtures. I did upgrade the tubes to a higher-end tube to improve the color rendition and efficiency.
The light is diffuse, even, and moderately bright without being glaring.
Old 07-13-2011, 06:19 PM   #16
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
We are just trying to get our AS road worthy then the real work starts. I got a great deal on some LEDs just in case we would try a boon-dock run first time out. 6 LED pads as replacements for incandescent in original fixtures, got it on Ebay for less than $40. My wife liked the results so much I paid much more next time I saw another pack of 6 available. I didn't think she would like the "bright wight" but she did. check out Dan at LEDs 4, Recreational Vehicles. I don't have a 'point of reference' but I like his stuff!
captmatt is offline   Reply With Quote
Old 07-13-2011, 07:53 PM   #17
chaimemet's Avatar
2008 31' Classic
Ft. Lauderdale , Florida
leds
We just left Jackson Cemter and I bought bright LEDs to replace the halogen bulbs in the reading lights above the couch and master bed. At the same time I bought two to replace the fluorescent above the new SS sink. The LEDs above the bed are definitely an improvement. I have not installed the other yet.
chaimemet is offline   Reply With Quote
Old 07-13-2011, 08:46 PM   #18
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We have replaced all interior lights (both incandescent and halogen), including closets and stove hood, and the exterior door step, patio and compartment lights with LEDs. We wouldn't have it any other way. Huge improvement in low power usage when dry camping and far less heat generation. We chose white lights rather than the warm lights, and like them very much. We tried the warm colored LEDs but didn't care for the yellowish light. So far we have not had an LED fail.
TB & Greg and Abbey Schnauzer
#3954
Old 07-13-2011, 08:47 PM   #19
GeocamperAS's Avatar
1974 Argosy 28
1978 Argosy Minuet 6.0 Metre
Wauwatosa , Wisconsin
Images: 37
Dan's the man....."led4rv.com" . You can get the phone number from the web site. Dan knows his stuff.
GeocamperAS is offline   Reply With Quote
Old 07-13-2011, 09:22 PM   #20
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I replaced everything everywhere on my Safari with LEDs two years ago - for current draw / battery life issues ... I usually run off of solar panels while boondocking. Got 'em at www.superbrightleds.com in St. Louis. Not cheap, but no failures. Markedly reduced current draw ... the brightest I have draw about 375 ma, if I recall correctly. The current draw per lumen is about on a par with low voltage fluorescents, but the service life is much longer. I just replaced the automotive type bulbs in the cheap fixtures in my trailer with equivalent LED-on-circuitboard warm-white types.
Haven't used a pro light meter on them, but though the the output is completely adequate, it appears slightly less than the replaced incandescents. And as to heat output; it's negligible. There is some, of course, but I can't feel it by hand and haven't bothered to take temperature readings. It's really trivial.
Also, so I can read while someone else aboard sleeps, I got an older "Tensor" type desk / reading light for $1 at a resale shop and rewired ity bypassing the internal transformer so it could work on 12volt, put a 12volt plug on it, and put in a directional LED bulb. Voila! It also makes for terrific up-close task lighting for fly tying, extracting splinters, etc.
After all this, I also converted or replaced all of my flashlights to LED bulbs - the batteries now last for years of my light usage.
AirsDream is offline   Reply With Quote
Old 07-13-2011, 10:02 PM   #21
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We installed LED's well over 2 years ago and 25,000 miles or so and none have failed. I spent more for better quality and it has paid off. We boondock sometimes and they use very, very little power and we have one as a night light and it takes so little battery that we can leave it on all night. The halogens in the main cabin were so bright I replaced them with LED's with fewer lumens and now the lights are strong enough to see well and not so bright as to be garish. Then we replaced every other light but the main wardrobe and the step light.
Gene
Old 07-13-2011, 11:09 PM   #22
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
This is what I did... In the 58 flying cloud...
ddstech is offline   Reply With Quote
Old 07-13-2011, 11:11 PM   #23
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
We replaced our inside lights with LEDs and could not be happier with the results. Most of the camp sites Becky and I like to stay at don't have hookups and the lower power drain minimizes the amount we need to run the generator to recharge the batteries. We got ours from Dan at Led4rv.com. Service was great and shipping was free.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 07-13-2011, 11:12 PM   #24
ddstech's Avatar
Folsom , California
I am considering a new career as a hand model, but also you may notice the lights I used. Brand is lumatec. I like the name because it sounds like lunatic, which is what I am for spending so much on led lights for a trailer.
Matt
Old 07-14-2011, 06:37 PM   #25
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Yeah Dan! led4rv.com rocks!
He even has a section for LED's for AS.
Old 08-01-2011, 09:59 PM   #26
1974 25' Tradewind
Berryville , Virginia
71 trade wind
hi,
I am doing over a 71 trade wind and want to change to led. I do not like the center plastic light cover , vent combo set up ( plastic is now degraded) and want to change to something else using led. Does anyone have any clever ideas or dealt with this in a attractive way? I am not really interested in keeping the original items, more in getting a clean look with good lighting and venting.
batt is offline   Reply With Quote
Old 08-02-2011, 05:34 AM   #27
2005 30' Classic
Images: 12
I like the idea of saving my batteries when out and about without services, and I do like to get away from the crowds from time to time. But LEDs hurt my eyes. I have replaced my tail lights with them, but haven't replaced my backup or marker lights yet because of cost and discoloration with the light through the amber lenses. I have no intent to go LED with reading lights. Would not be surprised if they come out with some study about how bad they are on your eyes - somebody will sue, and some kind of regulation will result. Seems to be the American way today ....
GetOutDoors is offline   Reply With Quote
Old 08-02-2011, 06:44 AM   #28
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
I would go with LED's. I posted what I did a few weeks ago on another thread. Here is what I did. Previous Post I made some wooden frames to go around my fantastic vents.
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
LED Interior lights Matt Kline Lights - Interior & Exterior 1 02-19-2011 05:31 PM
