Old 07-22-2018, 02:11 PM   #1
2018 22' Sport
Springboro , Ohio
Tighten LED marker light
How do I tighten down this light. It’s on a 2018 Sport 22fb. I’ve pushed, pinched, pulled, twisted, and cannot see how to easily remove the amber lens cover. I’m assuming underneath I’ll find a screw that needs tightening. Any tips?
Rubeyjj is offline   Reply With Quote
Old 07-22-2018, 02:14 PM   #2
AVS
2018 27' International
Chino Hills , California
I'm going to follow this one... I have the same issue.
On one I have a broken clip as well, but I don't know if I have to replace the whole light or not. I can't find the clip alone.
AVS is offline   Reply With Quote
Old 07-22-2018, 03:11 PM   #3
Retired.
. , At Large
The light assembly is held onto the chrome base by a pair of spring clips. One at the narrow end, one at the wide end. Carefully pry the light off the base from those spots, then carefully pull it out of the way, so you can tighten the screw. Again, be careful, since the wires are going to be stuck through the hole in the body with Vulkem/Adseal.
Old 07-22-2018, 05:46 PM   #4
2018 22' Sport
Springboro , Ohio
Thanks Overlander. So does this picture show the 2 black clips you’re referring to? This looks to me like the current light fixture I’ve got. Gonna need a pretty thin blade to get in there, but if this is the way it clips on, I can see what to do.
Old 07-22-2018, 07:18 PM   #5
2019 30' International
Pennsylvania , Pennsylvania
The lens clips are real, REAL, tight. Keep working at it and it'll pop off. Chances are good there isn't much wire to play with when it does. But yes, that's how you'd get it off and tighten down the base.
majorairhead is offline   Reply With Quote
Old 07-23-2018, 09:47 AM   #6
zapper's Avatar
2007 25' Safari FB SE
2017 30' Flying Cloud
Highland , California
Very nice job guys, very nice. It would have been a difficult job to figure this one out without breaking something.
zapper is offline   Reply With Quote
Old 07-23-2018, 06:45 PM   #7
2018 22' Sport
Springboro , Ohio
When I get up to the trailer in a couple days, i’m going to try and push some dental floss down in between the base and the lens, and then pull back to push the spring clamp thing. I’ll see if that works without scratching or breaking anything.
Old 07-29-2018, 08:11 PM   #8
2018 22' Sport
Springboro , Ohio
So I was able to separate the lens from the base by working in a credit card and then running it around the perimeter while slowly lifting up. Took a while but popped out after I had both ends sufficiently lifted. The clips were not what I expected. I was expecting a plastic clip that pushed back and released, but they were the metal clips that spring against the slot edges, so they do fit snugly and can be tough to wiggle out. Found that the screw hole was stripped and unable to be tightened down so I cut a sliver off of my Mr Grip stripped screw hole repair kit ($1.99 at Ace Hardware) and pushed it in and put the screw in tight as could be. Repair complete, the light is now snugged up to the skin. Be forewarned, there ain’t a whole lot of electric wire to play with when the light fixture lifts up. Just enough to turn the lens and tighten the screws. Not too bad. Took about 15 mins.
Rv marker light led conversion BarnacleBill Lights - Interior & Exterior 0 02-19-2018 08:10 PM
LED Marker light upgrade cp1977 Lights - Interior & Exterior 10 08-22-2016 02:47 PM
Amber LED Marker running/turn light Dan@LED4RV Commercial Listings 0 07-19-2013 02:20 PM
LED Marker light grounding. briheath Lights - Interior & Exterior 13 05-31-2009 07:33 PM
