Old 09-13-2008, 12:20 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Third Brakelight on Airstream
Has anyone put a third brakelight on there Airstream.I sometimes wonder if they are noticable at night that much.They are LED light but I have only 2 of them.Has anyone tried doing something like this?I am going to look around and see if I can find something.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 09-13-2008, 02:34 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
do you mean up above the back window... It might be more visible but you can see the other just fine right? Why the extra work....????
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-13-2008, 02:38 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you think it's needed - this ought to get you noticed:
LED Tailgate Light Bar Brake Light* by Toucan
Old 09-13-2008, 02:49 PM   #4
2011 25' FB Flying Cloud
Anywhere & , Everywhere
This something that I've also thought about. Would probably be difficult to wire in a high mounted brake light but how about a unit similar to what they're making to add turn signals to existing mirrors which uses a small radio transmitter to control the remote light? If you haven't seen these here is a link to one:
Turnsmart Turn Signal Mirror, Signal Mirror Kits, Side Mirror Signal Lights
Not sure if something like this is made in the way of a high mounted brake light.
Al - K4GLU is offline   Reply With Quote
Old 09-13-2008, 03:05 PM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I had thought about this too and am giving serious thought to wiring in one on the inside that would show out the rear window. I would like to set it up where I could unplug it while camping and open houses but plug it back in for traveling. The existing brake light wires would be accessed through the inner skin behind the bath cabinet since its flush with the rear wall under the window. I've got some engineering to do to make it work but I think it could be done.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-13-2008, 04:12 PM   #6
purman's Avatar
1968 28' Ambassador
Do all of you not think your brake lights of the trailer are bright enough? have you been rear ended???
I'm not sure what the point of one is????
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-13-2008, 04:28 PM   #7
_
Originally Posted by purman View Post
Do all of you not think your brake lights of the trailer are bright enough? have you been rear ended???..
not only are the older lights NOT bright enough, but bulbs burn out quickly and the light up is SLOW...
the newer LEDs a/s tail lights are WILDLY bright....
http://www.airforums.com/forums/show...2&postcount=22
http://www.airforums.com/forums/f311...hts-23544.html
http://www.airforums.com/forums/f37/...ion-17847.html
and yes REARENDING does happen....
http://www.airforums.com/forums/f42/...ler-17704.html
devo....
i've got the 'light bar' ganglin linked, on the truck...
it really is bright, easy to attach and wire and would work nicely on the 'stream tail too!
cheers
2air'
Old 09-13-2008, 04:31 PM   #8
purman - What don't you understand about safety? If there is no need for one on a trailer why are they used on cars/trucks? Do you need to be rear ended before you try and take steps to prevent it? I think a high mounted brake light is a great idea and I don't even drive at night!
Old 09-13-2008, 05:32 PM   #9
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I have seen them.They are bright. Apperently the Motor vehicle association and Insurance institute agrees, they are standard on all cars now.
I think they look good on the back of an Airstream. Right below the rear bathroom window, but above the License plate.
I have seen an Airstream Rear ended, The picture was posted on these forums.
mustang is offline   Reply With Quote
Old 09-13-2008, 06:00 PM   #10
Devoman's Avatar
Light
The Airstreams are great during the day and on a clear night maybe.But what about those hard rainy days or those really foggy times.I always have trouble and I hate it when I have to look harder.I do slow down on the roads also but what about the next man or woman who does not.
Putting one on the inside rear window would be a good spot.I even thought about maybe one of those hitch type brake lights also.You could mount it to the bottom of the bumper.Or maybe fix it to sit on top of the tag light right at there eye level.
My vehicle is even setup to put in a rear foglight for those foggy days.From what I know these are standard overseas.Just a clear white light on one side of the vehicle.You will see that even Airstream overseas does the little extras.If I remember correctly.Here is an example from Airstream Europe.You can even see the clear fog light and extra safety light.Even though we dont get them why not make it better for yourself.
Product Family | Airstream Europe : Airstream, overview of the most recognizable caravan in the world
Old 09-13-2008, 06:51 PM   #11
Devoman's Avatar
3 Light
Here is site that I thought was really intresting.Everything is either billet or Aluminum.Pretty cool stuff but just a little pricey.
LED Taillights LED Lights led taillights led lights Led 3rd Brake Light Custom Cars Classic Hotrods Streetrods-Watsons StreetWorks
Old 09-13-2008, 07:44 PM   #12
_
Originally Posted by Devoman View Post
...My vehicle is even setup to put in a rear foglight for those foggy days.From what I know these are standard overseas.Just a clear white light on one side of the vehicle...
but clear/white REAR projecting lights used while driving, are ILLEGAL in the usa, i think.
red fog/rain lights are ok, i've got 2 on a euro station wagon, but some folks are annoyed by them.
so the euro 'stream photo, the right/red is ok here, but the white/left is NOT.
those are nice led/brake lights u linked, buy one and post pix of the install.
cheers
2air'
Old 09-13-2008, 09:29 PM   #13
purman's Avatar
1968 28' Ambassador
I do understand about safety!!! IF there is no need then Why arn't they putting them on trailers?????......Only cars and truck ???.... None on semi trailers???
I asked a question, didn't make a statement......Don't need to get snippy.
I'm not saying don't do it.. And I would agree about putting LED light on instead of the old ones.. I'm gonna do that... You already have 3-4 lights across the top of the trailer. plus your break and running lights... If someone rear ends you It's not because they don't see you.. It's because they are following to close....
I just wonder how much of a difference it will really make... It will only light up when the brakes come on, so if it is foggy there gonna hit you regardless...
Wonder if you could rig your top red running lights into your break lights, then you wouldn't have to add lights...
Just a thought...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-14-2008, 03:18 AM   #14
Images: 59
The original purpose of the light was so that the cars two or three back could see your brake light through the windows of the car behind you. I think the lights on your airstream are high enough that you don't need one.
But it's your airstream. If it looks cool do it!
Jet Blue's Mobile Airstream Classic 350 at Colonial Airstream Colonial Airstream Classic Motorhomes 21 10-02-2011 03:05 PM
Really Cool KARE 11 piece on MN Airstream Park & Airstream AirstreamFan Airstream "In the News" 4 09-19-2006 04:25 PM
Airstream Parks: North Texas Airstream Community/NTAC RivetED Link Archive 2 11-26-2004 07:56 PM
