Old 09-14-2008, 05:53 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
As someone that has been rear-ended more time than he cares to count, I think a 3rd brake light is a good idea. Of course, I also think there is no hope for someone that hits something as big as a house sitting in front of them, but that's another story.
I was looking through the products on the website that Devoman provided the link to, and found this, I think it would be an excellent addition to the 3rd brake light:
Brake Light Pulsator
Get their attention fast when your brake lights pulsate at 300 pulses per minute (5 per second!). Simple two wire connection - cut the feed wire to the light(s) and install the STOP-ALERTTM with the terminals provided. Works for third brake lights or main brake lights or both. Solid state, uses no additional power. Rated at 60 watts continuous (5 amps incandescent), great for two #1157 bulbs or Ultra Brights plus a 3rd brake light (for Halogen taillights, one per light is needed).
Only 1-3/4" x 7/8" x 1-1/8.
#AM-01 (each)
$30.00
Old 09-14-2008, 05:55 AM   #16
Well Preserved
1993 21' Sovereign
Originally Posted by purman View Post
Wonder if you could rig your top red running lights into your break lights, then you wouldn't have to add lights...
Just a thought...
I have seen the center clearance light rigged this way on local delivery trucks (like bread vans). I don't know how "legal" it is, but I thought it was a good idea, especially with a regular clearance light on either side of it.
Old 09-14-2008, 07:01 AM   #17
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Originally Posted by 2airishuman View Post
but clear/white REAR projecting lights used while driving, are ILLEGAL in the usa, i think.
red fog/rain lights are ok, i've got 2 on a euro station wagon, but some folks are annoyed by them.
so the euro 'stream photo, the right/red is ok here, but the white/left is NOT.
those are nice led/brake lights u linked, buy one and post pix of the install.
cheers
2air'
The white light pictured is a reverse light. The red one is a rear fog. European cars are a hobby of mine. A rear fog light is simply a red light that is roughly the same intensity as a brake light, usually only on one side, but sometimes both. White lights in the rear are just as illegal in Europe as they are here.
Example of a VW Jetta with rear fog turned on:
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 09-14-2008, 07:36 AM   #18
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
We have a set of these on are 89' Jaguar.. They sit in the rear bumper.. You can turn them on and off from the dash...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-14-2008, 08:58 AM   #19
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
I like the idea of wiring in the top three marker lights if that could be done easily. For those of you who have removed the inner skins, where are the wires for those top marker lights located? Although, now that I think about it, I don't have any upper marker lights. Back to the idea of setting up a third brake light in the rear window.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 09-14-2008, 12:57 PM   #20
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Sorry about that .I had it backwards.It has been a while since I have fooled with my Touareg.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Jet Blue's Mobile Airstream Classic 350 at Colonial Airstream Colonial Airstream Classic Motorhomes 21 10-02-2011 03:05 PM
Really Cool KARE 11 piece on MN Airstream Park & Airstream AirstreamFan Airstream "In the News" 4 09-19-2006 04:25 PM
Airstream Parks: North Texas Airstream Community/NTAC RivetED Link Archive 2 11-26-2004 07:56 PM
