Old 07-27-2003, 07:45 AM   #1
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Thin Lite Install
After replacing the front vent over the fold out table, in the front of the coach, with a Fantastic Fan, I really missed the light fixture that was built into the old vent. The other day, I picked up a Thin Lite fixture and installed it. Wow, can't believe the amount of light it puts out. Uses less than a single bulb too, as you all know the original had SIX bulbs.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-27-2003, 08:20 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Thumbs up
pick
nice install, where did you get the fixture?
john
Old 07-27-2003, 08:25 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Thumbs up
That is a nice install.
Old 07-27-2003, 09:27 AM   #4
overlander76's Avatar
Send a message via ICQ to overlander76 Send a message via AIM to overlander76 Send a message via Yahoo to overlander76
That light is nice. Did you just use the wire from the old light?
Seeing how we're talking about vents and lights, what are people doing about broken plastic on thier vents? If I had the replacement material it looks easy to pop a new one in place.
overlander76 is offline   Reply With Quote
Old 07-27-2003, 09:38 AM   #5
montanaandy's Avatar
Thin Lite Install
Pick:
Nice job on the FF & Thin-lite install. This is exactly what I want to do - I have the parts (FF & Thin Lite) but was looking for the step-step that had been in the photo section of the Forum. Did you take pics of the FF install/Thin Lite install that would be available? Thanks,
Montanaandy
montanaandy is offline   Reply With Quote
Old 07-27-2003, 10:50 AM   #6
"what are people doing about broken plastic on thier vents?"
That is an opaque pexiglass. I replaced mine with clear Lexan. The Lexan has more impact resistance but clear was all they had at the home center when I needed it.
It is held on with rivets (drill out with 1/8th" bit) and Vulkem. Just cut the new panel to size with a jigsaw. If you want to work on it off the trailer, the cover comes off by removing four screws on the slides. You have to remove the screen first.
Or put in a Fantastic Vent fan.
By the way, a temporary fix is to take a piece of cardboard the right size, wrap it several times with aluminum foil, then cover it with aluminum tape (you DO carry aluminum tape with you, right?). Mine lasted for months that way without a drip.
Mark
Old 07-27-2003, 11:15 AM   #7
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
John, I got the fixture at Wests Marine. They have a store in our area. I think you can order off of their website too. According to the box it draws 1.3 amps Less than a single bulb. Fixture was $54.95. They have a nice square fixture that would work in that area between the fan and the antenna crank.
Nothing to the install, just drill 4 mounting holes and a 9/64 hole to feed the wires through. Used old wiring from original fixture, for both fan and lights. Use some rubber grommets for the mounting screws, between fixture and ceiling, as it is an arched ceiling, and you will distort it if you tighten the screws all the way down.
For my FF install I used Dabler's photos over at Airstreamphotos.com.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 07-27-2003, 11:39 AM   #8
A better fluorescent ---
Pick,
I was after the same effect as you and was about to order the ThinLite as that is what you see in most stores.
I did a web search and found what some electrical experts say has better ballast electronics which make the bulbs last longer.
The best price according to SunRay's rep is at Camper's Choice:
Click Here for the light
(This is my first try for a link, so hope the above works)
Steve
Sav'h Steve is offline   Reply With Quote
Old 07-27-2003, 11:45 AM   #9
Well I see that it works! I'll use that more often...
BTW, They also have a CLEAR lens that is not shown for the same price. I like it better and the Co Rep says that there is no other difference in the two lights.
I think the reason you don't see more of the SunRay products in catalogs is because of their margin. Rep says 95% is sold directly to the Manufacturer as OEM.
Steve
Trouble Drilling to Install Anti Sway Cams DEO Hitches, Couplers & Balls 21 02-26-2004 05:15 AM
Should I install AC myself? Bryanhu Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-22-2004 11:26 AM
A/C Install for 1955 Overlander Tinovations Furnaces, Heaters, Fireplaces & Air Conditioning 10 02-23-2003 11:18 PM
Bath lites a new type of lite FrankR Electrical - Systems, Generators, Batteries & Solar 2 03-16-2002 08:38 AM
