Old 02-28-2009, 08:07 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
The front door lights...
Hey Inland I have another one for you. The is the door light (overhead), and the scare light to the side on this 1970 27' model overlander...is the light bulb inside the scare light the same kind (small clear) we use on the interior? Ones that you push in a little and twist to the side? The light over this door has a short in it and it did work...went to replace that bulb and it is really hard to get your fingers in there to make insertions.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 02-28-2009, 08:31 AM   #2
I am not at my office, but if I remember correctly, both bulbs should be 1141.
Old 02-28-2009, 03:28 PM   #3
1970 27' Overlander
We placed one bulb in the scare light fixture and it worked! Now we are after re-wiring the light fixture up above the door. Thanks again Inland.
Old 02-28-2009, 03:33 PM   #4
You don't have to wrestle with the door light bulb.
Take the cover off.
It's held in place with screws.
You may find the socket is history.
If so, new sockets are available, but the new style uses a "plug in" type bulb, making replacement of the bulb much easier.
Front Running Lights Sanders Lights - Interior & Exterior 7 07-24-2008 07:33 PM
Front Marker Lights 12 V Question spat61 Land Yacht/Legacy Motorhomes 4 11-05-2007 09:36 PM
67 safari no front running lights bonrab Lights - Interior & Exterior 2 10-21-2007 04:44 PM
Front Marker Lights spat61 Land Yacht/Legacy Motorhomes 3 10-06-2007 08:46 PM
Front Clearance Lights Chaplain Kent Classic Motorhomes 2 07-13-2006 10:29 AM
