Old 11-11-2009, 05:33 PM   #1
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
The External Turn Signal fiberoptic light
So the cover is busted to this light which I believe is the turn signal light run by a fiber optic cable, very high tech 70's stuff. Any body know if it can be replaced- just buy a cover or the whole "original" or a similar replacement?
RichHog is offline   Reply With Quote
Old 11-11-2009, 05:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Yes, it can be replaced, usually with an aluminum part, available from most Airstream dealers.
Old 11-11-2009, 05:55 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I got one from Inland RV a couple of weeks ago. About $15. You could also probably make one yourself.
Old 11-11-2009, 06:21 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here it is from another dealer:
Cover for the Turn Signal Indicator 680453 [680453] - $16.95 : ODMRV , Out-of-Doors Mart
Old 11-11-2009, 06:45 PM   #5
Metal and plastic covers are available.
The rest of the optic system, has not been available and is not likely to be repairable, without ripping out the walls, as it cannot be spliced.
Old 11-11-2009, 07:24 PM   #6
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Sometimes, what happens is that the red plastic inserts cloud with age. You can pop them out and use a very light grit sandpaper to make them new again. It worked for us.
The stainless steel cover is definitely the way to go. I got mine, when they were first made....I wish I could remember which member made them, but it was first-rate work.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 11-11-2009, 07:43 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Are these what your talking about - glad your still happy with yours..!
And They Are Done....
Here is a photo of the finished product. Asked the shop to keep the CAD program for these in case there is ever more demand. Will send everyone a PM that wanted one.
Old 11-11-2009, 09:18 PM   #8
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
Fiber Optic Cover
So looking at this pic it looks like part of the old plastic from the original is still attached. Dang, just placed an order from ODM a few days ago Am I missing the red plastic inserts? That would face towards the front I take it?
Old 11-11-2009, 09:22 PM   #9
Well Preserved
1993 21' Sovereign
The red plastic lenses are in the black block. They face forward so you can see them in you rear view mirror.
Old 11-16-2009, 04:31 PM   #10
San Angelo , Texas
Images: 37
That would be them! Sorry, Gary, I forgot who I bought it from. It's kept its luster and works great.
Thanks again.
Frederic
AIR # 8239
EX-WBCCI # 8371
Brake light / Turn signal issue Miss Vicki Lights - Interior & Exterior 4 05-28-2009 04:51 PM
Turn signal lens 76sovereign Lights - Interior & Exterior 15 01-29-2009 11:46 AM
Turn Signal Problem tphillips Lights - Interior & Exterior 4 01-04-2009 04:20 PM
Turn signal problem! Dale M Electrical - Systems, Generators, Batteries & Solar 6 06-22-2006 05:25 PM
turn signal problem Cruiser Electrical - Systems, Generators, Batteries & Solar 9 10-25-2004 06:27 PM
