Old 05-05-2019, 05:56 AM   #1
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thank you LED's for RV's...
Got a great deal from Dan on 12 Led strips for the F-tubes⚡️.
I wanted them for conservation👍 but the DW hated the obnoxious bright white dot's...🥺
They can still be seen a tiny bit but my 🤐 are sealed.
A Compromise was in order...🥰
ID:	339763   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
"Never tow faster than your Guardian Angel can Fly"
Sweet Streams....🌥
Old 05-05-2019, 06:34 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
So you put the LED strips ďbehindĒ dead fluorescent tubes to diffuse the LED squares?
Old 05-05-2019, 07:08 AM   #3
YEP👍
🤓 Diffuse...I new their was a werd for it.🤔
Molly Ivins
Amanamus
Sweet Streams....🌥
Old 05-08-2019, 04:48 AM   #4
Houston , Texas
F-tube LED replacement
You do know that you can get LED tubes that mount in the existing fluorescent tombstones, with diffusers, right?
Carbon footp is offline   Reply With Quote
Old 05-09-2019, 08:05 AM   #5
Dan@LED4RV's Avatar
Denton , North Carolina
great to see progress
Bob, great to see you made progress. It is a pretty easy change out once you get your mind around it. Some folks have found some plug and play bulbs in LED but there is no power savings if the Ballast is still used.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-09-2019, 08:10 AM   #6
Dan@LED4RV's Avatar
the bulbs come out
Originally Posted by SteveSueMac View Post
So you put the LED strips “behind” dead fluorescent tubes to diffuse the LED squares?
Steve, the bulbs come out and stay out. The Ballast can stay in there but needs to be disconnection. Here is a video that shows how.
https://youtu.be/HlDGW2lPUkU
Dan Brown
Denton NC
Old 05-09-2019, 08:18 AM   #7
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Been dealing with Dan@LED4RV for over 10 years. His stuff is great, and he does stand behind his products if there is a problem. Changed over all the incandescent lighting first in my 1994 AS LY diesel pusher, and then in my current '87 AS Excella. More than pleased!
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 05-09-2019, 09:08 AM   #8
Exactly why I didn't want to leave the ballast in and get the LED tubes...didn't make sense.🤔
Thanks again Dan..
Molly Ivins
Amanamus
Sweet Streams....🌥
Thank you! Thank you! Thank you! littlebird Winter Living 0 03-18-2014 08:48 AM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 12:03 PM
