Old 03-17-2009, 01:59 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Taillight wiring, where does yellow wire go
Have some interior panels off and was looking at the taillights and notice I have a yellow wire in the third can from right that goes nowhere, the taillight on the other side is the same, this can has a dual filament bulb in it, is this suppose to go somewhere?
On both sets of taillights the end of the yellow wire has no connector on it, is corroded and does no look like it was ever used.
If it is not used can I hook up the brake lights to this for better visibility for the person behind me.
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 03-17-2009, 03:39 PM   #2
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
On a 7 way trailer light plug yellow is the back up lights.
Dose your trailer use a 7way plug?Some older plugs where 5 way.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 03-17-2009, 03:55 PM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
You should already have brake lights. Back up lights would be cool since you have it apart, maybe one of those irritating buzzer things.
Over59 is offline   Reply With Quote
Old 03-17-2009, 05:20 PM   #4
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
The first light on the left looking a picture is the the turn/brake light, second is back up light, third the one with the yellow wire is a running light I assume, fourth is a clearance light, fifth is a reflector.
It does not look like the yellow wire was ever used, I just want to make sure of that.
Bruce,
Taillight problems Fishboy Lights - Interior & Exterior 3 12-29-2008 09:10 AM
Taillight Housing slow-canoe Lights - Interior & Exterior 3 06-26-2007 05:13 PM
Taillight Bulbs Trailer Girl Electrical - Systems, Generators, Batteries & Solar 17 09-10-2004 04:19 PM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
