Old 06-25-2007, 09:21 PM   #1
1975 26' Argosy 26
London , Ohio
Question Taillight Housing
I have a 1975 Argosy 26 foot motorhome, on the rear where the tail lights are mounted in some kind of plastic housing that goes clear acroos the rear. The problem is the mine has some cracks in it and I would like to know if and with what can it be fixed with.
slow-canoe is offline   Reply With Quote
Old 06-26-2007, 02:16 PM   #2
Streamin 65's Avatar
Columbus , Ohio
Images: 14
Some ideas to try.
I too have plastic light housings on our trailer, although they don't run all across the rear like your do, they were nonetheless cracked. To repair the housings I simply mixed up some 5 min epoxy and brushed on several coats over the entire housing. After it dried, I lightly sanded and painted the housings and they've held up well for 2+ years now. No new cracks.
I'd suggest taping the whole thing off so no stray epoxy drips onto the trailer, it would be a pain to get off! --dave
Streamin 65 is offline   Reply With Quote
Old 06-26-2007, 03:44 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Might even see if you can do without it or, there are lots of RV graveyards....
Old 06-26-2007, 05:13 PM   #4
That part has not been available for many years.
You can fiberglass yours, or as some have done, remove it and change to different light bezels.
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Wet taillight Pahaska 2002 - 2005 International 5 12-27-2002 01:16 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
