Old 09-10-2002, 05:26 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Taillight gaskets?
I replaced all rear bulbs in the tailight system of my '77 Excella 500. I noticed that there was a thin rubber gasket between the individual housings holding each bulb but none between the lens and the housing. The inside of the lens and the reflector (?) had dust and dirt in each one. While it wasn't extremely bad, did these lens start out with a gasket or not?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
roof vent gaskets Neenm Roof Vents, Skylights & Fans 9 09-06-2004 02:54 PM
New gaskets for Atwood 6 gal water heater j54mark Water Heaters, Filters & Pumps 0 01-03-2004 12:46 PM
Replacing window gaskets for late 60's rluhr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 10-23-2003 11:26 AM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
