Old 02-13-2003, 07:29 AM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
taillight bulbs
The rear taillight bulbs on my '77 Excella 500 are not as bright as I would like. I replaced one several months ago and I noticed that the other was not working yesterday. I found that the bulb had seperated slightly from the metal base. Since it is a 1156 with single element/single contact on base, will the 50 watt halogen backup bulb advertised in J.C. Whitney or sold in auto stores work as the running tailight? I have also thought about replacing the other 1157 stop and turn signal bulbs with halogen. Also, is there a source of LED bulbs that emit light at a 90 degree angle from the base so that the LED is projected straight to the rear of the trailer?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-13-2003, 03:26 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
craig
i'd shy away from running lights that are too bright, people behind you might not see your brake lights when they come on!
maybe they are dim due to a poor or corroded ground.
john
Old 02-13-2003, 08:32 PM   #3
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Let there be light
I have seen more and more LED lights on the Metro buses and trucks. Is there a source of lights that would replace our 70's style square lenses? Or is it too much trouble to replace them. I know someone also replaced their yellow and red running (roof) lights with LED's, they must be fairly generic. Any sources out there?
I use a fifty watt halogen over my sink at home..... ouch, that'd be bright on the eyes at night, but it'd be a great back up light.
Marc
Old 02-13-2003, 09:45 PM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
LED Lights
I followed a FedEx truck in the fog and rain today that had round LED tail lights that probably could be transplanted into a lot of old Airstrean tail lights I have seen. They were really bright.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 02-14-2003, 08:59 AM   #5
LED Lights
LED lights are available for replacements on the vintage trailers that used the "wedding cake" style tail lights.
They however, are not cheap.
Best 7 inch one we could find, goes for almost $80.00.
BUT, the big advantage, is that the LED lights, are brighter in the daytime, than the old lights are at night.
Smaller lights are available possibly for the 4 1/8 taillights used from 69 to mid 70's. Our tests so far say that the LED's cannot easily be mounted in the original tail light bezels.
You can see a picture of an 7 inch LED tail light, on our web site, inlandrv.com, part number 65601.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Bulbs - Tail and Clearance Zed2 Lights - Interior & Exterior 3 07-13-2005 11:53 AM
Florescent light bulbs AccessMaster Airstream Motorhome Forums 5 11-30-2003 05:35 PM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
