Old 04-09-2010, 07:16 PM   #1
North Central , Ohio
Taillight access question
How can I get to the back side of the taillights? I have a '73. I need to test/repair the wiring and can't figure out how to get the light assembly out. Does each of the round sections come out? Any help appreciated. Thanks.
loving-life is offline   Reply With Quote
Old 04-09-2010, 07:44 PM   #2
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Hello,
My tail lights on my 71 are fastened from the inside of the exterior skin. How to remove without removing a section of interior panel I dont know. One of mine had been removed for some reason because it now is fastened from the outside. I thought I did notice when I had the rear bath removed that the one light houseing was fastened from behind.
Robert
bertro is offline   Reply With Quote
Old 04-09-2010, 08:11 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
bertro is right. They are fastened from inside the shell.
Yes, the individual lights come out of the housing.
I found that when I removed the tail light lenses and the buckets that held the light fixtures I was able to reach inside the housing to retrieve the bullet connectors inside.
Most tail light problems aren't the wires themselves. Bad grounds, weak socket springs and corroded connectors are the main culprits.
That being said I still had a grounding issue with one housing. After cleaning the housing behind the the buckets I added new ground wires to the housings and ran them through to the inside behind the bath cabinets. Then down to the C channel on the floor.
Good Luck,
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Painting furnace access door question. Chasmorgan Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-30-2009 05:23 PM
taillight cover question ryan3326 Lights - Interior & Exterior 7 11-16-2009 12:48 PM
Taillight problems Fishboy Lights - Interior & Exterior 3 12-29-2008 09:10 AM
taillight bulbs davidz71 Lights - Interior & Exterior 4 02-14-2003 08:59 AM
Wet taillight Pahaska 2002 - 2005 International 5 12-27-2002 01:16 PM
