Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 07-04-2007, 11:08 PM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Tail, running, clearance lights not working
Hi,
my running clearance and tail lights don't work.
I went today for trailer inspection and when we tried to light up those lights from the TV... nothing.
So the plug from TV was tested and there is power.
The flash and brakes lights works fine.
I opened the 7ways box inside the trailer to see how was the wiring and everything is clean and tight.
From the manual the green wire powered the lights I am looking for.
Any idea of what could it be?
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
https://rvcampreview.com
dufferin is offline   Reply With Quote
Old 07-05-2007, 03:26 AM   #2
1986 32' Excella
vledder , drenthe
Images: 8
put 12 volt on the green wire inside the 7 way box.
If lights work test if there is 12 volt on the green pin on the conector that is on the trailer
When lights are working but no 12 volt on the pin there is a fault in the cable
remcolent is offline   Reply With Quote
Old 07-05-2007, 06:07 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
On my Argosy I had to replace the female plug on the end of the trailer umbilical to the modern 7-pin. Had a wire come loose in there once and cause a similar problem. Check that too.
5 meter Langford Nahanni
Old 07-05-2007, 07:12 AM   #4
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
can I take 12V directly from a battery
TAC# : QC-1
my blog
Old 07-05-2007, 07:17 AM   #5
. , At Large
Yes, you can take 12v directly from the charge line running to the trailer battery.
Old 07-05-2007, 07:25 AM   #6
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
I checked from the plug and nothing is loose.
Is there any fuse for those lights. From the converter fuses panel I don't see any green wire coming so I do assume it's without but not sure.
As it's a serial circuit does a dead bulb mae the circuit open.
BTW I bad about electrical, usually I don't get nothing.
TAC# : QC-1
my blog
Old 07-05-2007, 07:28 AM   #7
. , At Large
It could be the umbilical cable that runs between the tow vehicle and the coach, where it plugs in to the trailer itself.
Old 07-05-2007, 07:32 AM   #8
2005 22' International CCD
Buckhorn , Ontario
START with the ground - on the trailer usually up on the A-frame - that can shut all your lights down real quick.
05ModPod is offline   Reply With Quote
Old 07-05-2007, 09:04 AM   #9
steelbird312's Avatar
2013 31' Classic
Crossville , Tennessee
Images: 11
Dufferin,
Check to make sure the ground connection on the trailer is good using a continuity check. To do this, touch one of the wires to the ground connection, and the other wire to a bare spot on the frame. IF all this is ok, then
Go to the autoparts store-buy a 12 volt test light that looks like an ice pick.
Then, clipping the alligator clip to a KNOWN good ground, touch each connector on the truck connector with the pick, and they should light up, if the items are activated (running lights, turn signals, brakes, etc) After insuring these all work, then plugg up the trailer, and, very carefully, stick the pick through the individual wires insulation, insuring the connector is good.
If both of these checks are all good, then you have a cut in the wiring between the front of the trailer, and the items the wires go to.
steelbird312 WBCCI #6673 jerry Hodge
2013 31" Classic limited
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand, throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 07-05-2007, 03:25 PM   #10
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
it is pouring rain in Nova Scotia today so I didn't really have the mood to spend too much time outside. Though I checked between two showers all the light and one ground wire is unplug. It looked in place but it's not. That's why I never notied it so far. I didn't dig enough. So it must be that. I'll check later to see if it comes from here. But sounds it's that.
But again I am not a fish and I have no taste to get out now.
thank for the advices...
I'll let you know.
TAC# : QC-1
my blog
Old 07-05-2007, 04:17 PM   #11
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
ok did check and it works. The problem is solved. Good. Not fix yet but at least I know where it is.
thanks for the help.
TAC# : QC-1
my blog
Old 07-05-2007, 04:42 PM   #12
Buckhorn , Ontario
Rivettes Rock - hmmm was that a girl who suggested the Ground first - OMG where is Michelle when you need her......
Okay you were all just lettin my held swell right????
glad you solved your problem...out east the invisible corrosion can be a mystery
Old 07-05-2007, 07:01 PM   #13
1972 25' Tradewind
Madison , Wisconsin
clearance lights
I thought I had some bad ones. When I popped off the caps and tested the contact, I got nothing. I used burnisher to clean the the contacts (after removing the bulbs) and tested again, I got power.
I then checked all of the running lights. Some were fine, some were questionable. My solution was to drill them all out and replace them with LED lights. They all work and are sealed. I still put a bead of marine sealant around the top and sides to shed water away from the contact wire. I left the bottom unsealed.
Wow do the LED's stand out. I am very happy with them. I will try to rmember to photgraph them tomorrow when I put the camel away. I have to put the second axel on in the morning.
Look into LED replacements, unless you are doing a restoration. I am doing a renovation so switching to something I regard as better (or different) is a go for me. Needless to say I am very happy with the LED's!
Smokin Camel is offline   Reply With Quote
Old 07-06-2007, 10:15 PM   #14
1972 25' Tradewind
Madison , Wisconsin
Led
These were shot under an open skylight in mid afternoon. At night they really stand out.
Name:	Picture AS Axel 4-07 056 (Small).jpg
ID:	40678   Click image for larger version
Name:	Picture AS Axel 4-07 057 (Small).jpg
Old 07-09-2007, 01:53 PM   #15
2013 31' Classic
Images: 11
Hey Duffrin
I am in your neck of the woods, beleive it or not. We are in St. Andrews tonight and tomorrow night, then a trek towards New Foundland, will be there until Sept or so. Plan on passing through Nova Scotia, and if time allows, will stop around Digby for some of those wonderful scallops!
Running Lights blowing fuses neil ervin Electrical - Systems, Generators, Batteries & Solar 11 04-30-2006 07:37 PM
How To Balance Running Gear Inland RV Center, In Axles 26 07-08-2004 03:14 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
Interior lights - 61 Bambi 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 06-07-2002 09:52 AM
