Old 03-13-2016, 06:46 PM   #1
Miami , Florida
Tail lights assembly
76 Tradewind totally gutted. Went inside AS in middle of strong rain storm. Surprisingly only 1 leak where old ac is but both tail lights had leaks. When rain stopped drilled out entire assembly, 3 little things that looked like rivet heads. Assembly came off and is very heavy. Parts for it are not a problem. HOW DO YOU INSTALL ASSEMBLY back against the trailer. No perforations, no holes. Totally lost.
Assembly looks like cast "aluminum" or something like it
Dave rem is offline   Reply With Quote
Old 03-13-2016, 07:07 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
On my '73, those assemblies are riveted from the inside of the trailer. You have to have the inner skins off to see it. Strange way to do it. I only know this because one of mine actually fell off a while back. I had to screw it back on from the outside with stainless steel screws. I think it's in a thread someplace. See if I can find.
www.nesa.org
Air No. 6427
Old 03-13-2016, 07:12 PM   #3
Got gandkids?
Here it is. Start reading at this post: http://www.airforums.com/forums/f226...ml#post1670817
Hope it helps some.
www.nesa.org
Air No. 6427
Replacement Tail Light Lense Assembly Swanny Lights - Interior & Exterior 5 07-02-2015 11:30 PM
Need to Replace Argosy Tail Light Assembly josephhhh All Argosy Trailers 25 02-11-2014 05:48 PM
Tail light assembly problems DanB Electrical - Systems, Generators, Batteries & Solar 1 05-03-2007 09:07 AM
Need '77 Argosy Motorhome Tail Light Assembly Panel adamstarr Lights - Interior & Exterior 1 09-29-2006 01:58 PM
Tail light assembly needed. AccessMaster Airstream Motorhome Forums 6 08-05-2003 07:35 AM
