Old 07-25-2009, 04:35 PM   #1
1973 31' Sovereign
Seattle , Washington
Tail lights
We have a tail light that is rusted out and needs to be replaced. Any ideas on how that can be done? I have attached a picture of the tail light.
everluvray is offline   Reply With Quote
Old 07-25-2009, 05:55 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Tail lights
Greetings everluvray!
I believe that Inland RV has an LED lamp set that is nearly a direct replacement for your tail lights. The only problem is that you loose the fiber optic lamp monitors if your coach is so-equipped.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-25-2009, 06:15 PM   #3
Unfortunately. the that can type tail light was discontinued a couple of years ago.
LED replacements are available.
Many companies have what they call 4 inch LED tail lights, but they are actually larger than 4 1/4 and won't fit.
But, a modifed version is available that fits just fine, but since they are sealed units, the tail light monitor will no longer function.
Old 07-26-2009, 09:50 AM   #4
1973 31' Sovereign
Thanks. One step down sounds like a light is available - any ideas on how to get the original light out?
Old 07-26-2009, 09:57 AM   #5
There should be 2 or 3 rivets that hold the can in place.
They may be installed backwards, (from the other side) but they can easily be sheared off.
Old 07-26-2009, 11:09 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
one of mine is so badly rusted in place, I couldn't get it out. those rivets ain't what's holding it in.
lucky for me, its only the reverse light, so it isn't "necessary".
I'm going to be doing some rear floor repairs soon, so I'll have to try to knock it out from inside, while I have the thing torn apart.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-26-2009, 11:28 AM   #7
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I converted mine over
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
'59 tail lights Jephellis Lights - Interior & Exterior 3 06-22-2008 07:29 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
'69 Tail lights. 69AmbassFl Lights - Interior & Exterior 12 03-26-2008 06:04 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 01:58 PM
