Old 02-07-2016, 07:07 PM   #1
2008 19' Bambi
SOMERS point , New Jersey
Tail lights
We just noticed one of the tail lights on our 19' Bambi are on but dim, although the trailer is disconnected from the tow vehicle. The light stays on , again dimly, when I disconnect from shore power. Any thoughts?
Laundry is offline   Reply With Quote
Old 02-07-2016, 08:59 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Hmmmm.... if I had that on my Avion, I would be looking for a wiring schematic and my trusty meter to figure out how that bulb is getting something near 12V DC provided to it when not attached to the tow vehicle. That's going to take some investigation, for sure.
I hope someone here has some personal experience or particular areas to look at in your Bambi.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 02-07-2016, 09:01 PM   #3
. , At Large
Probably the umbilical plug has some water in it, or a wire from the battery charge pin is touching the turn signal lead.
Old 02-07-2016, 09:08 PM   #4
PaulnGina's Avatar
Good Ol' , USA
I was wondering the same thing.
Is it your right turn signal by any chance?
Here is a site that I like for connectors and pin-outs for connectors (look down the page a ways)
http://www.crbrophy.com/elec.html
1987 Avion 34W
Old 02-07-2016, 10:40 PM   #5
1974 Argosy 20
Kooskia , Idaho
Post 3 and 4 have the answer. Water in the umbilical cord or plug causing leakage from the 12 volt charge line to the light. Takes very little power to leak and light the LED's dimly.
Old 02-08-2016, 05:35 AM   #6
2008 19' Bambi
Yes, it is the right turn signal.
Old 02-08-2016, 05:59 AM   #7
PaulnGina's Avatar
Good Ol' , USA
I asked that because the 12V blade and the right turn signal blade are next to each other in the umbilical plug.
If you'll refer to this link I gave earlier http://www.crbrophy.com/elec.html#f4ct and go near the bottom of the page, you'll see that blades 4 (12V) and blade 6 (right turn) are next to each other. I'd start looking in that area.
Just remembered I had an image of the plug wiring......
7 Way Blade Plug Trailer End
(View from back of plug where wires attach.)
1987 Avion 34W
Old 02-08-2016, 06:14 AM   #8
PaulnGina's Avatar
Good Ol' , USA
Here's another plug diagram that I think I saved from someone's post on AirForums. I like it because it shows the color code for the wiring:
Name:	ImageUploadedByAirstream Forums1435576560.545391.jpg
1987 Avion 34W
Ceiling lights flicker, tail lights are dim Zeitlupe 2011 - 2015 International 11 07-01-2016 07:29 AM
Anyone know of LEDs for the rear marker lights on mid '70s on the tail lights? Mixter Lights - Interior & Exterior 8 11-11-2014 08:27 PM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
